Links
Old 03-14-2008, 02:40 AM   #1 (permalink)
Default fl spark plugs replacement
i wanted to change the spark plugs of my 03 fl 2.5 v6. however, the spark plugs are buried into the ignition coil and it seems really impossible to get them out. so my question is. is there a specail tol to take the old spark plugs our or do i have to buy the whole ignition coils which are little bit pricey.
any help is apprecaited
thank you
bourouba is offline   Reply With Quote
Old 03-16-2008, 09:14 AM   #2 (permalink)
underneath the coil, take the bolt out and pull it out, how many miles on it?
Old 03-16-2008, 12:07 PM   #3 (permalink)
it has 79000 miles on it. do i need to change them now. if so is there a step by instructions how to do that
I alos have another question. I notice coolant smell when i drive for too long that's after i park it, the car does not oevrheat. I took it to the dealer and they said that the engine is good and there is no leak and i've been monitoring it and it does not seem to have coolant leak. last time i changed the coolant bottle however, i noticed that whoever owend the car before me put a green coolant instead of the pink one. could it be the wrong coolant the cause of the smell. i will flush the coolant this week and see if it changes anything. besides the pink coolant, do i need to apply some sort of sealant.
too many quesitons at one time. I really apprecaite your feedback roving4life.
thanks so much
Old 03-17-2008, 05:53 PM   #4 (permalink)
asked the dealer to make sure the engine wasn't changed or the timing belt.
if it wasnt you are due for them at 72k
its an eight hour job that you need special tools.
bottles leak, you can look yourself, check underneath the dashboard driverside, the fan has a big white sticker. if it is pink its got a heater core leak. look in the valley of the engine for a leak as well.
Bosch plats. Elemental The Lounge 9 02-13-2007 08:55 AM
Spark Plugs & Spark Plug Wires 2002DiscoII Discovery Series II 13 05-14-2006 06:58 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Spark plugs imag Discovery Series II 27 11-13-2005 03:27 AM
Best spark plugs for the Range Rover mr.rover Range Rover P38, Mk III and Range Rover Sport 4 10-11-2004 07:43 AM
