» Sponsors
» Sponsors
Old 08-06-2009, 04:45 AM   #1 (permalink)
Default Freelander 1.8 exchange engine waiting for gasket problem ?
Hi
I just bought Freelander 1.8 2002. After couple of weeks I noticed coolant water was leaking and after searching internet noticed that this engine has head gasket problem. After some investigation I found out that the engine was changed at the beginning of 2008 with land rover´s exchange motor LBB111740E. I contacted local Land Rover Importer and their technical specialista and also a mechanic from service assured me that this engine should not have overheating and head gasket problems any more (stated that there had been some desing improvements). I just wonder if this is tue ? Does the part number tell anything about engines structure ? Now the car is in service and they found leakedge from some external part by pressurizing cooling system. Water was still pink and clear after 2000 km drive. I just added clean water regurarily to keep water level up (1-1,5 liters during 5 weeks / 2000 km)
arnovi is offline   Reply With Quote
Old 08-06-2009, 11:18 PM   #2 (permalink)
Got the car back from service. They changed intake manifold gasket. Hopefully coolant water stays inside for some time :-).
4.2L Motor w/less than 80K Paul Grant Land Rover Parts and Accessories 3 07-14-2008 04:30 PM
5 Benefits of Using Synthetic Motor Oils webmasteroiluk General Land Rover Discussion 9 07-09-2008 03:13 PM
Hey Ford Motor Company, want to make money, build this (Part 1) Adam in NYC USA General Land Rover Discussion 28 02-20-2007 02:42 PM
I've fix it, here are the result $200 v $0 sidawson Discovery Series I 0 06-07-2005 11:46 AM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
