Old 01-13-2005, 03:21 PM   #1 (permalink)
Unhappy Freelander rear door ?
I have rain water comming in, and soaking into the rear roof interior by the rear door, any ideas.
5 door 1.8
Thanks
Dave.
Dave UK is offline   Reply With Quote
Old 01-16-2005, 01:35 PM   #2 (permalink)
5 door 1.8
Thanks
Dave.
its probably the internal door seal they wear in the corners where the window moves up and down, mine did the same ,a new seal did the trick.
pete t is offline   Reply With Quote
Old 01-17-2005, 02:24 PM   #3 (permalink)
Default water ingress in rear
The water can leak in through the top finisher and on to the metal plate under it,
there is 5 screws that hold it on water can leak in through these to test tape up the upper finisher to the roof and check for water ingress.
The fix is to remove the finishers (they break) and re seal the screws to the roof with sickoflex this usualy works ok.
MG-FRANCE is offline   Reply With Quote
