Fuel Cap lock replacement - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 3 (permalink) Old 01-23-2010, 12:26 PM Thread Starter
Quoted: 0 Post(s)
i bought a new gas cap without lock and cannot get the lock out of the old cap. Does anyone know how to remove it?
crackmanus1 is offline
post #2 of 3 (permalink) Old 01-29-2010, 04:02 AM
Former LR tech, Albany NY
Quoted: 0 Post(s)
hold the cap and it should come out its not in really well. take a look at take it apart.
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
post #3 of 3 (permalink) Old 03-09-2010, 06:08 PM
Quoted: 0 Post(s)
Freelander Gas Cap Lock Removal/Replacement
Not sure if you figured it out, but for the benefit of others I thought I should post my findings. I have a 2004 Freelander HSE and just did the fuel cap switch-out.
There are pretty much 5 main parts to the gas cap:
(1) the top of the cap
(2) the bottom of the cap which spins and secures the plug in place
(3) a big spring inside the bottom of the cap
(4) a little black locking tab at the bottom the cap bottom (more on this later)
(5) the lock cylinder/key mechanism
To get the key cylinder out (obviously the cap is off the car and the key is still in the lock), you press the bottom on the cap (#2) in against the cap top (#1). You'll see a little notch in #2 that allows a small tab from #1 to fit in, locking the two together. This lets you turn the key a bit more (counter-clockwise) and releases a small internal locking tab (#4), which allows you to pull the cylinder out. Keep in mind that #4 actually holds #1 and #2 together, so be prepared so you don't lose the spring (#3) in case you want to keep the old cap.
When you pull the cylinder (#5) out, you'll see #4 still attached to the end of it. Simply pry it off with a small screwdriver and then push #5 into the new gas cap (take a look inside the new cap to make sure you're lining up #5 to clip into the new #4, which is already inside the new cap).
That should take care of it!
DrWarmth is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Lock Actuator Replacement legacy1 Discovery Series II 5 06-03-2009 12:24 PM
05 Fuel Filler Cap Replacement jlonigro Freelander / LR2 0 02-20-2008 09:32 AM
Fuel Filler Cap Release w/o Front Harness Connected Sign Guy Range Rover Classic 0 01-19-2008 03:34 PM
'88 RRC Fuel Cap needed djromaric Land Rover Parts and Accessories 0 02-09-2007 04:40 PM
Fuel Filler Lid or Gas cap cover Won't Open gush Range Rover P38, Mk III and Range Rover Sport 5 04-07-2006 12:08 PM
You may post new threads
You may post replies
