freelander 2004 HSE ,,fault code
P0304
P0306
P0303
P0300
P0150
P1472
P0174
i replaced all coils and plugs and vis motors and still misfire ,don't know what to do.can you help me ?
i had the same problem ....i mean same code make sure you seal the VIS motor real good ,,,no air leak..doesnt mater if you replace the VIS if you didn't seal them it will give you the same misfire..
Did you fix your misfire codes to your Freelander? I too switched out both VIS motors as well I switched out the following;
New intake gaskets, o-rings (green ones), sealed w/ atv gasket sealer the plenum edge (but not the VIS motors). Triple double checked my vacuum lines. New spark plugs and coils. What else did you do to fix your misfires?
What was the fix for the P1472 code? I have the same one just came up on an 04 2.5V6 SE Freelander
Related Threads
507.6K posts
71.3K members
Since 2004
