Old 11-27-2005, 05:37 AM   #1 (permalink)
Question HP for Freelander 4cyl SE3 1.8 cc
Hi fellas
Eventhough I have the workshop manuals I was wondering if one of you actually knows hoy many Horse Power does the 4-cyl 1.8 cc have?
My freelander is 99 and the model is the SE3.
Thanks for your help buddies
The Pope is offline   Reply With Quote
Old 11-27-2005, 03:01 PM   #2 (permalink)
It is about 82 kw
garrycol is offline   Reply With Quote
Old 11-27-2005, 10:25 PM   #3 (permalink)
Hope this helps
Capacity 1796cc
No of cylinders 4 in-line
Bore 80mm
Stroke 89.3mm
Compression ratio 10:5:1
Cylinder head material Aluminium
Cylinder block material Aluminium
Ignition MEMS 3.0
Fuelling Multi-point fuel injection
Valves per cylinder 4
Valve actuation DOHC with hydraulic tappets
Maximum power 86kW @ 5500rpm
Maximum torque 165Nm @ 2750 rpm
This is the spec for the 2004 model
scubaboy is offline   Reply With Quote
Old 11-28-2005, 10:44 AM   #4 (permalink)
Thumbs up Thanks Buddies
That will do, the new models are quite different than mine.
Regards
