Hi fellas
Eventhough I have the workshop manuals I was wondering if one of you actually knows hoy many Horse Power does the 4-cyl 1.8 cc have? My freelander is 99 and the model is the SE3. Thanks for your help buddies ![]() |
Hope this helps
Capacity 1796cc No of cylinders 4 in-line Bore 80mm Stroke 89.3mm Compression ratio 10:5:1 Cylinder head material Aluminium Cylinder block material Aluminium Ignition MEMS 3.0 Fuelling Multi-point fuel injection Valves per cylinder 4 Valve actuation DOHC with hydraulic tappets Maximum power 86kW @ 5500rpm Maximum torque 165Nm @ 2750 rpm This is the spec for the 2004 model |
