» Sponsors
» Sponsors
Old 12-22-2008, 10:29 PM   #1 (permalink)
Default Loss of Power, & Engine warning light
2002 Canadian Freelander driving at 100km per hour, when engine warning light with an exclamation mark in. The power then also died, and if you try to accelerate there is little to no response. If you try to restart it just makes a clicking sound. It will start if you use booster cables, so initially thought faulty alternator and duff battery so have replaced the battery, but the fault still happens. Any suggestions.
itwe74 is offline   Reply With Quote
Old 01-12-2009, 09:28 AM   #2 (permalink)
go in change timing chain engine going if not done engine screwed
auggy11 is offline   Reply With Quote
Old 01-12-2009, 10:35 AM   #3 (permalink)
Brad
Exclamation
get it looked at, then look for a new motor if its the timing Chain/Belt.
Brad 97' Disco1
MyDisco1 is offline   Reply With Quote
Check Engine Light garrycol Freelander / LR2 4 02-01-2007 04:59 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 08:53 AM
Service Engine Light 1999 Discovery SD Patrick52 Discovery Series I 9 07-20-2005 01:03 PM
Disco power loss caters Discovery Series I 7 01-02-2005 07:50 AM
