Links
Old 03-26-2008, 08:59 PM   #1 (permalink)
Default Loud Rumbling - Help!
Hi Guys,
My Freelander has a loud rumble to it. It's hard to work out where it's coming from. If anyone else has experienced this problemn could you tell me what it is. Someone once told me it the tailshaft viscous or something????
Ta - GC
Spysee13 is offline   Reply With Quote
Old 03-26-2008, 10:19 PM   #2 (permalink)
Oh and by the way - its a 1.8L 1999 model - ta.
Old 04-26-2008, 04:30 AM   #3 (permalink)
Hi ,could be the viscous coupling,or the prop shaft bearings,or an outside chance its a rear wheel bearing,viscous is very expensive,you may be able to buy a re con off e blog,the others are relatively cheap ,also may be the universal joint,all do it yourself tasks,hope you sort it,by elimination,percy
percy is offline   Reply With Quote
Old 04-27-2008, 06:27 AM   #4 (permalink)
take the propshaft out and see if the noise goes away. you can drive them around without it.
Whistling noise while accelerating (rather loud) jarnism New Member Introductions 1 02-13-2008 09:15 AM
'03 HSE loud squeal inside Captain Ducman Range Rover P38, Mk III and Range Rover Sport 18 08-09-2007 07:04 PM
Loud squeal when turning? williampdx Discovery Series I 19 01-26-2007 03:44 PM
HELP! Very loud tapping at speed/under load only? acameltoe Discovery Series II 9 10-10-2006 06:11 AM
Radio problem - LOUD buzzing jmpolyak Range Rover P38, Mk III and Range Rover Sport 8 01-20-2005 02:32 PM
