LR2 Key Fob Battery Replacement Instructions - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 13 (permalink) Old 06-17-2012, 01:10 PM Thread Starter
Underwater hockey is no dumber than any other sport
Roverdude's Avatar
Quoted: 0 Post(s)
The battery in my primary LR2 key fob had been getting wonky so I replaced it, figured I'd share for any interested parties (It's not too difficult, but if you're a ham-fisted solderer you may want to practice on some old electronics or seek assistance from a more soldering proficient buddy):
The battery is a Panasonic LiON VL2330 (Panasonic - VL2330-1HF - Batteries - Battery - Allied Electronics). I got it for $8.10 + shipping (~$5).
Step One: Remove emergency key, CAREFULLY pry case apart.
Step Two: Carefully remove circuit board and battery. See first photo- the battery has two prongs, one fat (orange oval in pic), one skinny (orange arrow). You will have to de-solder these prongs. The battery sits in a little plastic cradle- you can pop the cradle off its' mount so as you de-solder, the cradle will pull the prong out of its' hole. Be very careful of other electronic components in the vicinity!
Step Three: carefully de-solder the holes so the new battery can be installed.
Step Four: Solder in the new battery. The cradle will hold the prongs on the circuit board making soldering fairly easy.
Step Five: Test the fob.
Step Six: reinstall circuit board, carefully press fob back together. I had to gently squeeze mine in a vice to get it to slide in and out of the key dock normally. I've heard some folks have used adhesive to keep their key together. I don't know whether it was due to part of the case breaking while splitting or a different key design.
Use and enjoy!
ID:	31593   Click image for larger version
ID:	31594   Click image for larger version
ID:	31595   Click image for larger version
ID:	31596   Click image for larger version
"Guinnevere" '91 RR - SOLD
'08 LR2 SE
2010 MINI Cooper S Convertible
1995 Porsche 911
Roverdude is offline
post #2 of 13 (permalink) Old 08-13-2012, 01:44 PM
chiefsfan122000's Avatar
Quoted: 0 Post(s)
Great post! Thanks! I followed your instructions and now once again have two working fobs.
chiefsfan122000 is offline
post #3 of 13 (permalink) Old 08-28-2012, 10:46 PM
Quoted: 0 Post(s)
Since I have never soldered a thing in my life, nor do I have the guts to, any idea who might give this a try for me? Would an indie attempt it, or maybe a PC, repair shop? Sounds like the toughest thing for an expert may be open ing the FOB.
ROverdude, you don't happen to be anywhere in the Orange County area??
RedstarBG is offline
post #4 of 13 (permalink) Old 03-12-2013, 06:53 AM
Quoted: 0 Post(s)
Use and enjoy!
Indeed, wonderful post, thank you for all this valuable informations and this photographic tutorial, which I will be of great use.
snowglider is offline
post #5 of 13 (permalink) Old 06-28-2013, 05:43 AM
Quoted: 0 Post(s)
Use and enjoy!
This worked very well. For step 1, I used two flat head screw drivers. Worked them around the edges till they popped the case. It took some work and patience. I did some damage to the plastic, which was filed down, looks good.
All the other steps worked like a charm. I used adhesive to mine back together.
Thanks for the instructions. They were great.
Slice_Shaper is offline
post #6 of 13 (permalink) Old 09-18-2013, 07:41 AM
Quoted: 0 Post(s)
I have come across alot of misinformation about the LR2 key FOB. There is indeed a battery in there, and the Fob comes apart quite easily. I placed a screw driver in the the hole slot that houses the emergency key and pryed the 2 pieces apart and wedged another flat head in the gap I created and worked it around the perimeter of the FOB until it unhinged. 1192.photobucket.com/albums/aa329/Bdiem/IMG_0876_zps2e0b20dc.jpg[/IMG][/URL][/IMG]
[IMG][/IMG]
tylerdurden is offline
post #7 of 13 (permalink) Old 09-21-2013, 02:04 PM
Quoted: 0 Post(s)
Instructions were great. Like you said the key fob is a pain to get apart. All done and with success. Wouldn't say mine looks pretty, but good enough for a spare!
Justinv is offline
post #8 of 13 (permalink) Old 11-15-2014, 12:40 AM
LR2
Quoted: 0 Post(s)
Thumbs up THANK YOU Roverdude!
You just saved me nearly $700 that I thought I would be stuck paying for two FOBs. Phewwwww!
MrNapa is offline
post #9 of 13 (permalink) Old 11-21-2014, 11:42 PM
LR2
Quoted: 0 Post(s)
Okay, seriously, thank you roverdude for this original post. I purchased two batteries from the allied link you provided. Along with your post, I used the following:
Originally I sought out a electronics repair guy, but he quoted me $60 per FOB and inspired zero confidence that he would do the work correctly. I understand that he can't give me a guarantee, but his attitude about his "time" being worth $60 per FOB rubbed me the wrong way; at least give me a $30 now -- $70 more when it works. I'd have willingly paid him $100 per FOB.
Anyway, instead I went to an electronics shop and asked the gentlemen there what I would need to do the repair. I have never soldered before so I was really clueless about what I would need. Thankfully they hooked me up with all that I would need--and for cheap! I paid $30 for an soldering iron, helping hand with magnifying glass, solder with rosin (I think), and some copper wick.
For others considering doing it yourself, GO FOR IT. Just be patient. The effin FOB is hard to get open. After cracking open the FOB, I got right to work on de-soldering. The large hole was very easy to do. The little hole ... not so much. That took a long time, nose-pliers, and a small burn to get done. Still, in just about 45 minutes, I was done and my FOB works! I can't believe I was operating without one ...
Anyway, thank you for this post. Now, I just hope that someone answers my post requesting suggestions/recommendations for spare change (quarters, etc.).
MrNapa is offline
post #10 of 13 (permalink) Old 02-17-2015, 12:16 AM
Quoted: 0 Post(s)
I followed your instruction carefuly and got my key fob soldered.
After the big procedure (took about 1 hour) the key still wouldnt work,
I tested the battery and the soldered spots with a Volt-meter, there is enough voltage, so the key should be working fine actually, but doesnt.
I opened the doors with my working key, but used the fixed key to start the car, did this for about a week, but still the key wouldnt work.
Do you have any instructions on how to reprogram the key? Maybe there is any interference with the transponder after the batterychange.
Mine is a LR2 SE td4 built 2007.
Thank you for any comments.
macboateng is offline
post #11 of 13 (permalink) Old 06-09-2015, 10:08 PM
dondon_des
Quoted: 0 Post(s)
2011 Land Rover LR2 Locked Out after vechicle was idle for 30+ days
My 2011 LR2 may remain idle for more than 30 days. I received a call from my sister who tried to unlock the vehicles. The FOB could not open the vehicle. She tried both FOB's and neither worked. I spoke with a LR Roadside agent who told me if the vehicle is not used for extended periods of time, the FOB will stop working. He said I need to manually open the door, place the FOB to the side of the steering wheel to deactive the alarm and try starting up the vehicle. If the problem was not related to the battery, the vehicle will start and the FOB will lock and unlock the vehicle.
With this in mind I will take his advice and give it a try once I return home for the 4th July holiday.
Any comments?
dondon_des is offline
post #12 of 13 (permalink) Old 06-23-2016, 02:41 AM
Quoted: 0 Post(s)
Hello,
Did you get an answer to your question?
I have the same problem with my key fob.
After replacing the battery, it doesn't work anymore...
I think I have to reset (program) it?
My email address: giovanni.jeckyll@outlook.fr
Many thanks
giovanni is offline
post #13 of 13 (permalink) Old 08-26-2016, 11:08 PM
Quoted: 0 Post(s)
Try inserting key fob in the car and leave it for half an hour for recharging. It may work. The battery is a rechargeable one.
Dr. Manish is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Key FOB wont open vehicle, dead battery! ladyrangeowner Range Rover P38, Mk III and Range Rover Sport 3 05-20-2012 06:36 AM
battery in key fob how to open Pastfast04 Range Rover P38, Mk III and Range Rover Sport 2 02-13-2012 05:44 AM
Ugh... Key fob battery replacement. MatchuPitchu Discovery Series I 3 01-23-2010 11:52 PM
Key Fob replacement? lsawicki Range Rover Classic 8 12-27-2008 07:35 PM
Factory alarm keyless fob battery replacement? andrewcconti Range Rover Classic 1 12-24-2008 07:37 PM
You may post new threads
You may post replies
