Old 05-22-2006, 04:30 AM   #1 (permalink)
Default Map reading light not working
Just a quick problem ( I hope)
After water leaking through the centre consol lights ( problem now solved), how do I get to the map reading lights. I think that water must have got into them.
I can remove the centre light cover, but cannot see any obvious screws or ways to get the to map reading bulbs
Thanks in anticipation
Andrew
tedshred is offline   Reply With Quote
Old 05-22-2006, 04:50 AM   #2 (permalink)
just pull down on it - it just pops out as a unit - from the headliner.... no screws. just try not to break it
maybe a small flat screw driver will help to pry it a little...
jaguiler is offline   Reply With Quote
Old 05-22-2006, 04:51 AM   #3 (permalink)
thanks will try this tonight
Old 05-23-2006, 01:19 AM   #4 (permalink)
Thanks for you help,
When I took the unit out it was blackened inside and part melted. Looks like it’s a replacement
Thanks again
Andrew
