This is an EASY repair.
It requires no opening of the system at all or any special tools. Took me about 30 min total this morning on the wife's 08 @ 25k miles.
I'm somewhat pissed about the cost from the dealership and plan on letting LR USA know this.
DO NOT clamp the lines. It could destroy them, esp if steel braid is included in the hose. You will only need to bleed the brakes if you open the system, ie pop the piston out, or have some leak.
GET THE FACTORY PARTS, every thing you need is included in the box. 4 pads, 4 caliper bolts, 4 carrier clips(2 upper/2 lower), and a pictogram instruction set. Also factory parts are backed by factory warranty, fit correctly, and they cannot blame the parts for causing something else to go wrong.
No special tools either, a big c clamp, or large channel lock pliers will do nicely for retracting the piston, 13mm ratchet for the caliper bolts, a thin 14mm wrench for the carrier pin nut (a thin pliers will do fine too these are not that tight), and that is it.
When I get some time later I'll type up the step by step and post it along with the parts # and scan of the pictogram.
best...
