Old 08-16-2006, 06:44 AM   #1 (permalink)
Default New 38mm Lift Kit Freelander
www.straight-up-lifts.com
drop-pants is offline   Reply With Quote
Old 08-16-2006, 02:10 PM   #2 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by drop-pants
That is pretty cool. Now I want to see some pics of lifted Freelanders.
Old 08-18-2006, 01:34 AM   #3 (permalink)
It is hardly worth it for a measly 38mm - 50mm would be better
garrycol is offline   Reply With Quote
Old 08-30-2006, 08:21 AM   #4 (permalink)
Oh yes.. there will be blood.
chrisvonc's Avatar
Here's mine with a 2" DAP lift
Chris von C.
Sick of how slow LRO has become with all the ad's? Rage Against The Banners!!
If you use Firefox, install the add-on AdBlock Plus. All ads gone and the site loads like greased lightning again.
chrisvonc is offline   Reply With Quote
Old 08-30-2006, 08:59 AM   #5 (permalink)
01001010's Avatar
Gallery: 15
This is my buddy's Freelander with a 1" lift
JC...
1965 Series IIa 109 RHD Dsl - Wilks
www.TerraTrekker.com
Old 10-05-2006, 06:33 PM   #6 (permalink)
The purpose of our kit is to avoid the cutting of interior body panels and the removal of the struts (altering brake line mounts).
Anything much over 38mm and the panels must be cut, and struts must be removed.
This design simply saves you time and extra work.
Old 10-14-2006, 08:34 PM   #7 (permalink)
do these lifts hurt your suspension at all, and I have a 2003 se3 freelander with 17 inch wheels, what tires do you guys recommend.
One last question, can you guys send me more pics of your lifted freelanders??
Blizwinter@gmail.com for pics
Thanks guys, wish I had some freelander friends in PA!!!
Blizwinter is offline   Reply With Quote
Old 11-01-2006, 05:33 PM   #8 (permalink)
With the 17" rims your tire selection is limited. Most with 17" run the Pirelli Scorpion AT. If you plan on taking it offroad, you should really consider getting some 16" wheels. There are many more tire selections in that size. I run 225/70/16 BFG AT/KOs. With that size there is no worry about rubbing even without a lift.
What part of the state are you in? I'm in Pittsburgh right now but from the Philly area.
lagged is offline   Reply With Quote
Old 11-05-2006, 04:57 AM   #9 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
That is one sharp looking FL!!!! What have you all done to it?!
Old 11-08-2006, 09:57 AM   #10 (permalink)
Otherwise known as STEVE
Yeah, Chris... nice Freelander.
I still miss that thing. Anyway- the original 2" lift for these is rally proven and only requires minor clearance work to ensure the steering rods won't bind on the inner fender wells. That should be done on any lift- there should be an extra margin around any moving steering part. The brake line mounts do NOT need to be modified as asserted... that's only if you don't want to disconnect the brake line and bleed the brakes.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 11-08-2006, 12:22 PM   #11 (permalink)
Here's the one I used to have,
Ironman springs, 225/75R16 MTRs
cboy is offline   Reply With Quote
Old 12-03-2006, 02:05 PM   #12 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
That's not the FL you tipped over is it!!
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 12-04-2006, 12:48 PM   #13 (permalink)
Yeah- it took a light roll onto the side.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
