Old 12-21-2006, 07:13 PM   #1 (permalink)
Default Newbie
Just purchased a 2004 Freelander HSE.
A couple of quick questions:
What tire pressures work best with the stock 18" wheel/tires?
Any advantage to using premium fuel over regular?
Thanks
cWadeb is offline   Reply With Quote
Old 12-21-2006, 07:58 PM   #2 (permalink)
Super Moderator
Disco's Avatar
Welcome aboard. The best tire pressure in my opinion is 38-40 PSI all round; Your owners manual will tell you differently, however, use the fuel that your manual says to use, any thing else is just wasting your money.
Old 12-21-2006, 09:52 PM   #3 (permalink)
Thor's Avatar
Tire pressures are on a sticker on the driver's door.
Fuel in owner's manual.
Todd
Carpe Rangius Roverum
Old 12-22-2006, 04:25 AM   #4 (permalink)
32 psi works fine.
This winter keep an eye on your coolant level otherwise you wont have heat or overheat?
Did you buy this vehicle at a LR dealer or private owner? How many miles on the vehicle.
Old 12-22-2006, 05:35 AM   #5 (permalink)
Otherwise known as STEVE
It was designed for regular fuel, use that. Higher octane fuel in an engine not designed to take advantage of it will cause harm long term.
On my wife's, when we run the 17" wheels we use tyre pressure in the high 30's because of the short side wall. Any lower than about 34 or so and it's easier to pinch a sidewall on a pot hole or something.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 12-22-2006, 07:27 AM   #6 (permalink)
Smile
Thanks for the responses, unfortunately I do not have an owner's manual yet - to be ordered. My experience with other vehicles sometimes led to tire pressures slightly different than the suggested or at one end of the suggested range. Just looking for insight as this is our first Land Rover.
2004 w/just under 34k, full dealer service history - no major issues: tail lamp bulb, replaced a cracked vacuum hose and a new battery, other than that just scheduled service.
Old 12-22-2006, 06:21 PM   #7 (permalink)
Did you buy it Land Rover Ceritfied.
Oh and when it comes time to do all the services make sure you have proof.
And stick to what the factory says or do beyond it.
Most of our freelander customers just change the oil and sometimes when things go wrong like an engine or tranny it bites them in the ass cause of the lack of proof.
