Links
Old 08-17-2005, 08:04 AM   #1 (permalink)
Default noisy......?
Hi Can Anyone Help I Have A Freelander 1.8 98s Just Bought It Its Got 100,000 On Clock The Car Drives Brilliant But It Seems Noisy When Driving It Makes A Drumming Noise Just Like A Wheel Bearing >fixed Temp Sender Cheer Guys
bart4729 is offline   Reply With Quote
Old 08-17-2005, 07:35 PM   #2 (permalink)
Check that the drive line viscous coupling has not frozen up - 98/99 models do this - could be causing transmission windup causing load on IRD and Diff bearings - a frozen VC (expensive) will cause the IRD and/or the Diff to fail - very, very expensive.
If VC is OK - check universal joints and bearings in the propellor shaft.
Garry
garrycol is offline   Reply With Quote
Old 08-18-2005, 11:20 AM   #3 (permalink)
cheers i will try this hope it works?
