O-ring question - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-29-2013, 06:31 PM   #1 (permalink)
Default O-ring question
Working on my boss's 2002 Freelander 2.5. I replaced the thermostat with one from Rover, and I must have nicked the o-ring on the manifold when I installed it. Any gurus know the o-ring dimension so I don't have to buy an entire new thermostat? Thanks, love the show......I'll take my answer off the air!!!
Jesus Joe is offline   Reply With Quote
Old 02-14-2013, 02:07 PM   #2 (permalink)
In case anybody runs across this problem....I found an o-ring that worked. It was a little tight on the OD, so I stuck it in the freezer overnight... I got it from fastenal. Part number 1166855. Here are the specs:
Product Standards
Temperature:
-40[DEG]F - 250[DEG]F
Cross Section Size:
0.125"
Color:
Black
Inner Diameter:
1-1/4"
Material:
Buna-N
Outer Diameter:
1-1/2"
Style:
Standard
Type:
O-Ring
Hardness:
70 Durometer
Trade Size:
#218
Application:
Hydraulic Applications
Product Weight:
0.0030 lbs.
Notes:
Buna-N O-rings, or Nitrile O-rings are all 70 Durometer with .003 Tolerance
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Radiator bleed screw and O ring question CROWNEWOURTH Range Rover Classic 4 11-23-2010 02:45 PM
Ring Gear Bolts Question helievacpilot Discovery Series II 1 01-07-2010 07:44 AM
red ring/yellow ring intank fuel pump howardw Discovery Series I 1 08-29-2009 09:47 PM
red ring/yellow ring intank fuel pump howardw Discovery Series I 0 08-29-2009 01:30 PM
SEO by vBSEO 3.3.2
