Old 11-12-2006, 10:09 AM   #1 (permalink)
karamela's Avatar
Unhappy Rear Door Problem
Hello,
I know theres lots of posts regarding the rear door problem but i tried everything and still i get to where i started:
1. rear window does not go down
2. wiper does not work
3. window heater does not work
The only thing i can do is open and close my door but with the window always UP !!!!!
i tried to disconnect the battery but that did not work.
when i trie to lower my window from my dashboard it only beeps.
the fuse is ok
when i open my door i hear a sound from the right side of my free ...
whats keft to do ????
karamela is offline   Reply With Quote
Old 11-30-2006, 09:36 AM   #2 (permalink)
Look for a loose connector in the harness going to the rear door. Since the window heater, wiper and window ALL do not work you have either lost power or ground to the rear door.
Rocky - Northern Nevada
04 Discovery S "JeepHerder"
Trans-Nevada-Trek Trailboss
RockyRon is offline   Reply With Quote
Old 12-02-2006, 09:40 AM   #3 (permalink)
All is tied in together, its possible you have a rear wiper motor not functioning
or a bad relay underneath the c pillar panel located above the rr strut.
If you get swap the relays and it works its possible the pins are being pushed out every so often on the relay wiring.
They are all tied in together and are a pain in the butt to diagnose.
If that all checks out then you need to hook up T4 to see what the vehicle is seeing as far as sensors on the rear door.
