Old 11-18-2005, 10:32 AM   #1 (permalink)
Default Service engine soon
Changed the oil on my Freelander 2002, and shortly after noticed the amber "service engine soon light". All fluids levels are correct.
Is there a reset for this?
hipp02 is offline   Reply With Quote
Old 11-18-2005, 10:33 AM   #2 (permalink)
needs to be diagnosed. Could be anything.
What type of engine do you have?
Old 01-10-2006, 09:06 PM   #3 (permalink)
My '02 did the same exact thing. I unfortunately have no idea either and I also learned a long time that 9 out of 10 times those lights are a false alarm and I tend to ignore them. (Regardless of make and model of vehicle) Call me crazy...
eyesbehindthelines is offline   Reply With Quote
Old 01-11-2006, 03:02 AM   #4 (permalink)
They can 'false' from time to time - disconnect the car battery for about 5 minutes - this clears the ECU memory. If the light was 'false' it will not come back on when the battery is connected. If it does come back on then there is a false indication and should be diagmosed. Likewise if it comes back on later - go through the same routine - if the light stays on get it checked.
garrycol is offline   Reply With Quote
Old 02-06-2006, 02:25 PM   #5 (permalink)
It just needs the Service Light resetting.
TEMPL4R is offline   Reply With Quote
