Links
Old 02-19-2007, 03:52 AM   #1 (permalink)
kin
Default SRS Warning Light On!
Hi I am new to this forum. I own a 2003 V6 Freebie, since a few weeks ago, the SRS warning light came on by itself and has not gone off since. The car is running fine & I can't find anything wrong with it. Can anyone advise why its on and how I can turn it off, I did search the forum and found a thread saying that the computer was replaced to fix it, I am hoping that I don't have spend that money just to trun the light off.
Thanks, kin
kin is offline   Reply With Quote
Old 02-19-2007, 09:02 AM   #2 (permalink)
Otherwise known as STEVE
It needs to be checked at a good Rover specialist or dealer. SRS faults can be serious problems... get it looked at by a competent shop ASAP.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 02-19-2007, 02:48 PM   #3 (permalink)
The light is on for a reason - it needs to be checked out - hopefully it is just a computer code that can be reset but if the SRS has a fault it may be a safety issue.
Garry
garrycol is offline   Reply With Quote
Old 02-19-2007, 08:14 PM   #4 (permalink)
kin
OK, I guess its time to pay again, thanks for the advises!
Old 02-27-2008, 12:53 AM   #5 (permalink)
Novice
Hi Kin, I have just purchased an 01 with the same issue, I was aware of it and got the car at a real knockdown price. If it is not a computer glitch (just a reset) then it will be the air bag control unit, located behind the heater controls under the dash. If you are willing to remove the dash (six hours labour as quote by LR) your can change the unit for one from a wreckers. Probably the cheapest option. Thats the way I plan to do mine
Alldapies is offline   Reply With Quote
