Old 09-28-2005, 10:54 AM   #1 (permalink)
Default Stall on pull away
Hi, can anyone give me any advise. I park my 02 TD4 on a slope, occasionally when pulling away it stalls after about 6 feet. The manual tells me I should drive away straight after start up, should I leave it to 'warm up' a little first though to cure the stall or will this have no effect at all (other than on the fuel consumption) !, also can anyone give an indication as to turn off when pulling up, some say let the engine idle for about 10 secs others sat about 30 to 60, which is best ?
steveland is offline   Reply With Quote
Old 09-29-2005, 12:30 AM   #2 (permalink)
When cold the engine doesn't like pulling, likewise the turbo doesn't come on line until about 1800-2000rpm so under that there is not a lot of power.
The simple answer might be more revs on take off to get the engine into its power zone - say 1800rpm.
Garry
garrycol is offline   Reply With Quote
Old 09-29-2005, 02:15 AM   #3 (permalink)
Super Moderator
Disco's Avatar
Your loss of power could be a result of either a dirty air or fuel filter, or both. Check these first.
Old 10-31-2005, 02:44 AM   #4 (permalink)
Do you have any info on removal of fuel filter from TD4, workshop manual no help.
susyhutch is offline   Reply With Quote
Old 10-31-2005, 02:00 PM   #5 (permalink)
The filter is on the left hand side of the engine compartment bulkhead.
Unscrew the filter housing and lift the housing - tilting away from the bracket. Disconnent the wiring multiplug
Put rags under the filter. Note locations of fuel hoses etc. Depress retaining clips and disconnect hoses.
Lift filter and filter head from bracket then unscrew the filter.
To install new filter - lubricate the sealing ring with engine oil and fill the filter with diesel. Screw in the filter to the filter head until just tight - hand turn a further 180 degrees.
Refit to the housing
Reconnect hoses as electrical connector - tighten
Apparently nothing else is required eg no pumps or primer or bleeding etc.
