Old 01-11-2006, 05:26 AM   #1 (permalink)
Default Swapping distributor rotors - How?
Hey all i'm not so mechanically minded when it comes to cars, but i need to change the distributor rotor in my 98 freelander. is this a simple task of unbolting on and off or do i need to take more care, in other words take it to a mechanic.
Cheers
Freelandin is offline   Reply With Quote
Old 01-11-2006, 05:54 AM   #2 (permalink)
Polish and proud of it.
TsiArt's Avatar
This is interesting .
Is this ford engine or Land Rover engine ?
How come it's not coil paks or coil on plug .
But anyway .
Do you need to pull the whole thing out of the block ?
If yes . Then yes you need to mark the position of the rotor when you pull it out , cause the gears are helii gears ( I don't know what they are called , but they have a twist to them) . So this way you can put it back in some what the same spot that you pulled it out from .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 01-11-2006, 03:59 PM   #3 (permalink)
Cheers
You just need to unclip the distributor cap - do not remove leads - the rotor should then just pull off - the new one can only go on one way.
garrycol is offline   Reply With Quote
Old 01-12-2006, 07:25 AM   #4 (permalink)
Ok, sounds pretty simple but is the whole leaving leads on thing of dire importance or just a way to leave the firing order right, because i'll be changing cap and leads aswell.
Thanks
Adz
Old 01-12-2006, 04:00 PM   #5 (permalink)
Thanks
Adz
Just to prevent confusion - make sure you mark or sketch a diagram where things go before you remove everything.
Old 01-14-2006, 07:22 AM   #6 (permalink)
Awsome, sounds too easy, just have to wait till the parts arrive now. Thanks for all your help.
Adz
Old 02-04-2006, 02:38 PM   #7 (permalink)
It is held on by a grub screw. This is Loctited in, so be careful.
TEMPL4R is offline   Reply With Quote
