Trans help please - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 6 (permalink) Old 03-23-2017, 01:23 PM Thread Starter
Quoted: 0 Post(s)
Exclamation Trans help please
02 freelander se 2.5 v6..........i have put in 2 transmissions with 2 gear boxes and having the same problem, works good for a couple days then loud noise and i pull it over. No lights on dash but vehicle only goes forward slowely, no reverse and when i try to push it in netural all wheels locked solid......towed it home both times and in my garage when you shift to reverse and all gears vehicle goes only forward........
Help help sos please......thanks
i have also just changed the crankshaft position sensor
trans fluid is full
brake light switch is new
tgwin68 is offline
post #2 of 6 (permalink) Old 03-23-2017, 03:59 PM
member
SafariDave's Avatar
Quoted: 28 Post(s)
Freelanders are re-known for failing transmissions, failing engines & coolant leaks, etc.
Dave
The City is a Jungle.
2005 LR3/ SE 4.4 Fancy Professor (my girl's LR3)
2005 LR3/Disco3 SE 4.4 The Rhino
(mine)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255 55 19"
1999 LR Disco II SD 200,900 miles (Sold)
1991 Range Rover Classic (Sold) 'The Turtle'
1988 Range Rover Classic (Sold) 'The Rust Bucket'
SafariDave is offline
post #3 of 6 (permalink) Old 03-23-2017, 04:09 PM
Quoted: 290 Post(s)
Yeah- at any given time we have several of them on the local Craigslists in the surrounding cities. All with the same problems. Nothing you can do- it's just deficient engineering and poor craftsmanship.
CT090 is offline
post #4 of 6 (permalink) Old 03-24-2017, 12:20 PM
Wounded Knee Moderator
ihscouts's Avatar
Quoted: 87 Post(s)
Any codes pulled? Two times using the original Jatco trans ECU?
97 SD - Altai Silver. Sold
94 Saturn SC2
Roverless and wandering
The three-position Lucas switch--DIM, FLICKER and OFF.
The other three switch settings--SMOKE, SMOLDER and IGNITE.
Ultragauge
Contact info for Paul Grant;
203-770-1699
Contact info for Will Tillery;
540-462-7353
ihscouts is offline
post #5 of 6 (permalink) Old 03-24-2017, 02:25 PM Thread Starter
Quoted: 0 Post(s)
No Codes same ECU
tgwin68 is offline
post #6 of 6 (permalink) Old 03-24-2017, 03:53 PM
ihscouts's Avatar
Quoted: 87 Post(s)
You might want to swap the trans ECU out and have it checked by a garage diagnostics box. Are you going to change it out again?
94 Saturn SC2
Ultragauge
203-770-1699
540-462-7353
ihscouts is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Freelander / LR2
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Trans help needed!!! LR4U Range Rover Classic 7 12-11-2010 04:00 AM
Need A ZF trans gvb in the mud Land Rover Parts and Vehicles Wanted 4 10-20-2009 02:48 AM
Hello - and question about trans smeagol Discovery Series II 18 07-09-2009 07:37 AM
04 RR Trans L2C Range Rover P38, Mk III and Range Rover Sport 0 03-07-2008 05:40 PM
04 RR Trans L2C Range Rover P38, Mk III and Range Rover Sport 0 03-07-2008 05:32 PM
You may post new threads
You may post replies
