Links
Old 12-09-2006, 12:29 AM   #1 (permalink)
Default Tyres for Freelander
Hi,
I have a freelander KV6 and an old rangerover classic.
I would like to use only one size of tyre on both. At present the Rangerover is fitted with 215/75/16 tyres and the Freelander with 215/65/16 tyres.
Is it possible to fit the freelander with the rangerover's tyres without it snagging anywhere?
darrylm is offline   Reply With Quote
Old 12-14-2006, 05:06 PM   #2 (permalink)
HMBFreelander's Avatar
Originally Posted by darrylm
Hi,
In general you can run tyres of up to about 28.5 inches diameter assuming stock wheels and no lift. The common choice is 225/70-16 which are 28.4 inches. Your 215/75-16s are about 28.7 inches diameter. That's probably not enough larger to matter unless you heavily load your Freelander to near max capacity.
Just a note about tyre sizes. The '75's are about 6% larger diameter than the '65's so you will see an effective reduction of about 6% in torque to the ground and also the same percent reduction in stopping force. The stopping is fine once you get used to it. You will notice the Freelander shifting down sooner when climbing. Probably not a problem unless you are planning on towing a caravan with the Freelander. An added bonus is the larger tyres make the spedo read more accurately.
Brian
2002 Freelander SE
HMBFreelander is offline   Reply With Quote
Old 12-19-2006, 08:14 AM   #3 (permalink)
Default Thanks
Thanks so much for the advice. Will definitely give it a try and advise you of the outcome.
