Old 03-20-2006, 04:03 AM   #1 (permalink)
Default vibrating front end
PLEASE HELP!!!!
does anyone know why my car vibrates at the front from the speeds from 35mph to 60mph then disapears and its not the wheels that need balancing that has allready bin done thank you.
david watkiss is offline   Reply With Quote
Old 03-21-2006, 07:51 PM   #2 (permalink)
You could have a loose tire rod but more importantly does it vibrate a bit thru the gas pedal.
What we see alot with low speed vibrations at around 35mph are the front CV joints going bad, you can shake the inners and get some play.
Old 05-09-2006, 10:58 AM   #3 (permalink)
Default ut ohh
mine starts to vibrate from 23ish till 32ish and some times it does vibrate through the pedal, any ideas what could be wrong with mine?
Dr.Barq is offline   Reply With Quote
Old 05-09-2006, 11:22 AM   #4 (permalink)
Otherwise known as STEVE
does it vibrate more when you are gassing is kinda hard? Does it vibrate when coasting and off the throttle? We're seeing a lot more CV's going out as the earlier Freelanders are getting some miles on 'em.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-09-2006, 08:07 PM   #5 (permalink)
Take the batteries out
garrycol is offline   Reply With Quote
