Old 08-22-2006, 08:35 AM   #1 (permalink)
Default Warning Lights (again)
Anyone know if there are any fuses to pull to stop the warning lisghts problem?
Rosie is offline   Reply With Quote
Old 08-22-2006, 10:07 AM   #2 (permalink)
He did what in his cup???
DevilDisco's Avatar
Rosie, you should post that question the in the Model Forums section, it will be easier to see there. In order to answer the question we'll need the age, model and possibly mileage. I assume you are talking about a DII. If you are then then its probably somehting to do with the brakes. You just don't want to pull the fuse on the light. The lights tell you when something my be wrong, you should at least have it checked before you try to start ignoring it.
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
