Don’t know if this is related to the hot weather
As a rule I don’t use the air-conditioning, although I do know it works. Over the past month I have noticed that after I have used the car there is a sizable patch of water under the rear part of the engine. I regularly check the fluid level and they are all OK. The water appears to be dripping from a 3inch hose half way across the back of the engine mount back plate ( just below the steering rack). Is this normal |
#2 (permalink) | |
1992 K-reg 200TDI Defender 90 (Eva) MSN - Geobloke@hotmail.com There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill |
#4 (permalink) | |
You don't have a problem - it is normal. Garry |
Life, love and Land Rovers
Remember that the a/c is activated when you are using the demister functions in order to remove moisture from the air. As a result this can happen all year around, and not just when you have switched the a/c on.
Cheers Blippie
:: www.horse-back.co.uk :: www.cameltrophyvehicles.com :: www.unison-greatwestern.co.uk :: www.blippie.co.uk :: |
#6 (permalink) | |
thanks for the info Garry |
