1976 Land Rover 109" Safari Diesel for sale (D.C.)
This is a 1976 Land Rover Series III Diesel(109" wheel span) Safari Model.
It is the elusive 5 door, safari model, with everything intact, Upgraded seats to the later Defender style seats, which makes it relatively comfortable.
Everything is operational, no defects, no nothing, it starts and runs every time, time and time again. It is also the highly sought after Safari diesel model, so mpg return is inching towards the 30 mpg, and you can bet that you will be one of a handful within a radius of maybe a thousand miles which has one of these.
(A full recon of the motor was done at a cost of 3000+ USD)
VIRGINIA TITLE, so you can actually register the car and DRIVE IT!
Besides the reconditioned engine it has new glow plugs, wiring, exhaust, etc.. etc... etc...
On a down note, it will not go much faster than 60MPH even though it does come with the famous overdrive system. However, it will get you to where you are going time after time after time again and again!!!
16,xxx miles are to be read on the odometer although undoubtedly this incorrect. I am sure it has turned the clock once already, like all these cars have. If you are interested in a car like this, do not let someone fool you that it only has 88xxx or 56xxx original miles!
Please understand that the car is not pristine, it has the usual rust in the usual places, and dings in places which adds character! However this is easily removed as parts for this car are both CHEAP and they bolt in place or out of place in a matter of minutes! Trust when i say that this will be the cheapest fixable car you have ever owned!
Thank you kindly.
