» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Vehicles
Old 08-01-2009, 07:28 PM   #1 (permalink)
diesel nut
Default 1980 Unimog DoKa 416
Not a rover but looks nice sitting next to my Series II and Defender--need to thin the heard.
Up for sale is a 1980 Unimog DoKa 416—Asking $41,500.00. This vehicle was refurbished in 2003 by Schuessler Unimog in Europe (see photos a-g) using a low mileage 416 complete chassis with a cab from a 1986 406 aircraft tug. At the time of the refurbishment the chassis had roughly 46500 Kilometers and the cab Speedometer had 95000 Kilometers---the truck currently has about 97000 Kilometers on the Speedometer—so the mechanicals of this truck are almost new. There were a few areas that rust beginning to appear on the cab and rear tail gate that I had repaired ( see before and after photos). This truck has a 24 volt sytem, air assist Disc brakes and is riding on Continental 365/80R20 MPT 81 Tires with good life left in them. This truck has standard axles with a top speed of 55 MPH (speedometer is in Kilometers)
Some of the other key items the truck has are:
-three way tipper bed and hydraulic connectors to the front
-Webasto diesel powered heater—heats both air in the rear of the cab as well as coolant
-New Redarc 12 Volt trailer brake adapter and actuatuator
-tail lights, US 7 pin trailer connector and rear wiring new.
-Fuel tank removed, cleaned, interior coated and exterior painted
-New aluminum fuel tank for diesl heater
-bolt on hitch for standard reciever
-Atkinson Vos “dog house” engine sound deadener
-interior of cab and pickup bed coated with Rino Liner
-new ignition switch
-new door window seals
-airline for filling tires
-Unimog jack
-spare fuel and oil filters---spare door seals new
Currently everything functions as it should. All fluids have been recently serviced and the truck will come with spare filters for the next service. I have been driving this truck regularly on Biodiesel/reg diesel and it has performed flawlessly. I will be installing an aluminum tank for the Webesto heater (see photos) as the Webesto units are not Biodiesel rated---this way the truck can be run on Biodiesel withouth it effecting the operation of the rear heater. With the Redarc brake controler all you need is 12/24 volt LED lights on your trailer and you can tow it without any issues. I will be installing a custom bolt on reciever so that a drop down hitch can be used for towing almost any type of trailer (see photos). The truck is located in Bend Oregon---buy it now and drive it over to the Northwest Mogfest (NorthWest MogFest)
Please feel free to contact me with any questions at 541-550-6300 or soncken AT gmail DOT com---www.eco-offroad.com
Photos of the truck can be seen at: 1980 Unimog DoKa 416 $41,500.00 - a set on Flickr
The only vehicle I might remotely consider for partial trade is a Mercedes 300GD SWB with automatic, A/C and limited rust---otherwise no trades.
Rust, Rust and More Rust
roverso is offline   Reply With Quote
Old 08-01-2009, 08:13 PM   #2 (permalink)
that thing is clean
xBEEFx is offline   Reply With Quote
Life Expectancy for 1980 Defender bingomh Defender 5 07-22-2008 12:15 PM
1980 2 door range rover 3.5 manual +overdrive for sale straightshooter Land Rover Vehicles 0 03-08-2005 01:38 PM
