1995 rrc (reduced!)$4500
Runs and drives smooth.151k miles,has new factory head gaskets,power steering lines,D&D cam shaft,gears w/chain,lifters,water pump,cooling hoses,belt,wires plugs,vacuum advance,exhaust system and Cooper Discovery AT3's.Also has Bilstien shocks,Old Man Emu 1.5 lift springs and Bilstien steering dampner.Has small rust spot on left rear.I have a new ignition switch to put in and will also need a right side Cat. and viscous unit in T case in near future.Body straight and inside clean.Check out on Asheville,NC craigslist.Call or text 828-333-2226..I almost forgot I also have a pristine rear upper tailgate from Land Rover to go in. The new items have less than 500 miles on them. $4500 OBO located in black mountain,nc
Reason: lower price
