1992 Range Rover Classic SWB Aspen Silver
3.9l EFI Borg Warner transfer box ZF Automatic transmission Full-time 4WD w/ 3.54 gears 165k miles View image at http://www.get-rhino.com/srangie/IM001518.JPG This RRC has been our run around town vehicle. It’s a good solid truck but does need several little things repaired on it to be back in tip top shape. We are starting on a 110 project and do not have the luxury of a spare vehicle right now. Below is a detailed list of the parts recently replaced and things needed to be repaired. The truck has very little rust on it and the usual spots like the floor boards, sills, back lift gate etc…are in fine shape. The interior of the truck has been Rhino lined for protection it has carpet & mud mats along with front and rear water proof seat covers. The truck also has a 2” body lift but still needs the correct radiator spacers and seat belt extenders installed. [Order from Red Rhino Products] It also has a Brownchurch roof rack w/ 4 lights [They need wired and one is damaged.] At one time it had a snorkel fitted and there is a hole in the front for it. All the windows work well. It is fitted with genuine wheels and 34x10.50 LTB Swampers which will need replaced soon. Asking $3500 obo. Recently replaced: Plugs & wires Distributor & rotor arm Ignition amplifier module Fuel pump & assembly 14CUX ECU w/ 4.0 chip & 5AM MAS Fuel filter Coil [Genuine Lucas] Complete Genuine transmission service All other fluids renewed Complete steering shaft assembly All engine belts Alternator & battery OME HD front & rear shocks Bearmach 3” HD spring front & rear Front Cardin style driveshaft Rear driveshaft u-joints Needs Repair: Seat belts Sun roof motor Headliner installed Electric seat controls Front left caliper hangs sometimes Coolant temperature sensor Washer fluid sensor Back tail gate latch is hard to open sometimes Needs new lower door speakers The fuel pump wiring harness worked intermittently so we wired it to switch Power steering pump leaks [The norm for these trucks] The rear bumper has been cut Door lock electronic actuators Email jason@get-rhino.com for more information. View the rest of the ad at http://www.get-rhino.com Click on [Vehicles For Sale] on the main page. Thanks for the space! Last edited by RedRhinoProducts : 09-27-2004 at 04:01 PM. |
