1990 Range Rover. Ivory White Paint and Tan Leather interior. Interior as a whole is in great condition considering her age (may or may not need a new head-liner). Exterior has Very few flaws (just a couple door dings and a stubborn upper tailgate) and the paint still shines. Engine is VERY strong and VERY smooth (120+k well-driven miles). Still capable of cruising at 90+mph.
• CD player, am/fm with Cerwin Vega speakers. • Brakes and steering damper along with all bushings recently serviced (NO steering wheel shimmy when going over a bump on the hi-way) • CV joints all brand-new ($3600 job) There is absolutely NO PLAY in the steering wheel! • Suspension was also recently replaced with ARB heavy-duty springs (1.5”-2” lift). • Bilsten shocks on all four • Wheels are 16”X7” American Racing steel rims (black) specially made for this model Range Rover • Tires (5) are BF Goodrich All-Terrain 245/75/16 (about 4k miles on them) Spare has zero miles. This set-up has the car sitting about 2” to 2.5” higher than stock. However, because of the wider footprint due to the wheel offset, the car seems to be even more stable on side-inclines or hi-speed turns. The wheels/lift/offset combination will also allow full articulation with no rubbing. • Original Tri-spoke alloys (4) with OEM Michelins also come with the car • Battery is Brand-new (3-22-06) • Newer alternator • Surco ¾ size Safari Roof rack with Spare tire mount and 2 light mounts Front Brush bars and tail-lite guards • Hella 1000’s up front and a brand-new pair of 4000 in the trunk (new-in-box) to mount on the roof-rack if you like • New exhaust was just put on last month I’ve taken very good care of this Range Rover thru the years and would like to see her go to someone who will appreciate everything that I’ve put into her (I’m not a wrench so all improvements and maintenance had to be professionally done). I live in the Chicago area (Evanston) and would be open to test-drives/viewings. First $5000 takes her home Call or email 312-403-0127 fatmat27@gmail.com |
