Due to some future changes in my life, I’m looking to trade my trail ready Disco I for a low mileage stock (or slightly modified) Disco II. Basically, I’m not going to be able to use my Disco on the trail much in the next few years, and I rather have as our daily driver something more stock than see this great trail rig go to waste in the city jungle. We downsized to 2 cars, so I need a Rover that my wife can drive the kids around and also do some easy trails once in a while.
Here is the list, and at the end there is a link with pics.
1995 white Disco, auto, 114,000 miles:
-Great Basin Rovers 4.11 gears
-Great Basin Rovers CVs
-Great Basin Rovers Front Axles
-Great Basin Rovers Front Driveshaft
-Front Range Driveline Rear Driveshaft
-Front ARB Air locker
-Rear ARB Air locker
-ARB Compressor and Lockers connected to LR factory switches
-Rovertracks Rear Axles
-RoverTym Front Radius Arms
-RoverTym Rear Links
-Rovertym Rear Shock Mounts
-Rovertym Rear top Spring Retainers
-Expedition Exchange Rear Lower Spring Retainers
-Rancho RS9000 w/ Adjustable Dampening
-Rancho RS5000 steering dampener/ relocated to Drag Link
-Rockware Catalytic Converters Skid Plate
-Rockware Rear U-Joint Skid Plate
-Rockware Rear Bumper
-Rockware Rock Sliders
-Fuel Tank Skid Plate
-Front and Rear Differential Covers Protectors
-Rovertracks Heavy Duty Draglink and TieRod
-TieRod ends w/ grease nipples
-DAP Front Underbumper Winch Mount w/MileMarker 9500lb winch
-Rover Solutions backpack rack w/ high lift mount.
-Optima Yellow top Battery
-CB Radio w/ Ant
-Additional 12V plug added in the rear
-6 disc changer
-Rear jump seat and rear AC
-Usually runs 33’’ tires (255/85/16), but now has city winter tires on so I can put it inside the garage when it snows. (Arctic Claw Studded 245/70/16). Like on “rails” on the ice.
All maintenance up to date and have mechanical records since new. Runs great and does amazing on the trails. Has the usual leaks but none are bad or require attention. Interior is in great shape, exterior shows some battle scars, see pics below (electric window still works). The ABS light is on because of the aftermarket front axles and no place to plug the sensors (so no ABS, better on the trail I think). The SRS light (airbag) is also on (so no Airbags either).
Pictures here:
http://www.flickr.com/photos/96619702@N00/
email:
chelo@du.edu
