Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Parts and Accessories
Old 05-09-2005, 06:52 AM   #1 (permalink)
Post Help empty my garage! Ton's of parts..
Okay everyone, it seems like the more I try to get rid of spare parts the amount in my garage grows! I need to get rid of as much of these parts as possible, NO DECENT OFFER will be refused. I can ship any of these items through FedEx without a problem. Email me direct if you have a question or would like to buy something.
These items are personal and are being sold through me NOT Red Rhino Products. I will need payment via a check or money order.
Jason Michaels
Stock Front Shock Towers 2
Spring Perches 3
Rubber Spring Isolators 3
Stock Rear Upper Shock Mounts 2
Rear Link Frame Bush 2
Front Spring Upper Bolt Ring 1
Discovery I Steering Shaft 1
Engine Mounts 1
Disco II Throttle Linkage 6
RRC Fuel Pump Ass. 1
Used Fuel Pump 2
Disco II Front Arm Rest Covers 1
RRC Genuine Seat Covers 1
[Ok cond, Tan, Fronts]
Disco I Leather Shift Boot 1
Disco I Rear View Mirror 1
3.9 Dizzy [Need rebuilt] 2
Bosch Coil 2
MSD Blaster Coil 1
Ign. Amp. Reloc Bracket 1
3.0 MAS 1
Misc. Plug Leads
Pass. Side Exhaust Manifold 1
Wabco ABS ECU 1
AMR2128 Sunroof ECU 1
PRC6859 One Touch ECU 2
AMR3248 Alarm ECU 1
PRC9949 Window Lift ECU 1
AMR2745 RRC Dimmer 1
PRC17em Code Reader 1
AMR 1173 1
RRC Gas Popper Button 1
Disco Fuse Box [NON GEM] 1
Disco Dash Buttons
"Black, Green, Yellow Relays"
ABS Pump 1
Disco I Stock Brake Lines 1
Disco I Airbags 2
SRS ECU 1
Disco I 14CUX Harness 1
[For parts only]
Disco I Factory Front Fogs 2
RRC Blinker Bulb Harness 2
Disco I DS Rear Lower Light Lens 1
Rectangle Hella Lamps 3
Round Tractor Lamps 2
Hella Battery Cut Off Switch 7
Sunroof Motor 2
Rear Window Wiper Motor 1
Disco I Door Lock Actuator 4
Disco I DS Mirror 1
RRC Window Glass ALL
[Various pieces]
Disco I Window Glass ALL
[Various pieces]
WARN Roller Fairlead 1
Freelander Fans 1
Disco I Mud Flap Brackets 3
P38A RR Air Bags 3
Disco I Front Seat Trim [TAN] 2
Tan Disco I Cargo Back Side 1
LT230 Parts
24 Spline Drive Flanges 3
Disco II Front Bump. Crush Cans 2
Stock Recovery Points 6
Disco I Rear Door Seals 2
Tranny Cooler Lines 2
A/C Line 1
Starters [NEED REBUILT] 2
Discovery I Front Bumper [Stock] 1
RedRhinoProducts is offline   Reply With Quote
Old 05-09-2005, 10:13 PM   #2 (permalink)
What is that?
you have a PM
-Ryan
vaden87 is offline   Reply With Quote
Old 05-10-2005, 06:35 AM   #3 (permalink)
that's the bushing that bushing that mounts on the ear of the frame which holds the rear link in place.
Old 05-10-2005, 06:40 AM   #4 (permalink)
Wheeler
SCSL's Avatar
Check your PM,,thanks
Old 05-11-2005, 06:53 AM   #5 (permalink)
Chicago Rover66's Avatar
lookin for a disco 2 front bumper for fog lights,is it still available.
2001 d2 se7
Chicago Rover66 is offline   Reply With Quote
Old 05-11-2005, 06:58 AM   #6 (permalink)
Arrow
Sorry the only one we had was for a Disco I and it didn't have the plastic, just the metal portion.
If you send me an email I will add you to my pending requests and let you know when some thing comes available.
Regards,
Jason Michaels
Old 05-11-2005, 07:15 AM   #7 (permalink)
here is my e-mail.......robg119@hotmail.com
thanx rob.
Old 05-11-2005, 09:07 AM   #8 (permalink)
window lift ECU
is it for a D1??? how much???
rov'n is offline   Reply With Quote
Old 05-11-2005, 10:22 AM   #9 (permalink)
DI or RRC, $25.00ea, email me direct. jason@get-rhino.com
Jason
Old 05-11-2005, 01:25 PM   #10 (permalink)
Super Moderator
02disco2's Avatar
You ever get your hands on a D2 Brush guard??
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
