» Sponsors
» Sponsors
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Parts and Accessories
Old 10-12-2009, 12:43 AM   #1 (permalink)
Default RTE3" springs, Foxs, and an ABS pump
Buy some parts!
Best way to get ahold of me is email, MaxYedor@aol.com
1 pair of Fox 2.0x10" shocks, valved perfectly for the front of a Disco1/2/RRC/Defender, and damn close to what the rear should be at, if you keep a light load in the back, they're golden, these are the same age as the springs, however old that is. The bodies, ends, bearings etc are all 9.5/10. 1 shaft is near perfect, the other has some superficial pitting, not near deep enough to worry about. The seals are good, no pressure loss over the last couple years. The stickers could probably stand to be replaced or peeled off if you're OCD like that, Fox would probably send you a new set if you called and asked nicely. If you pick them up for asking price, you get the rubber resivior isolators, RTE lower shock mounts and 4 spacers (you need 8 total, but the RTE upper spacers are Flaming POS's and got thrown away), and the 1 good D2 spring isolator I have, so you need to score 4 spacers, a 2nd spring isolator and some form of upper shock mount and you've got a set of Fox's for the front of your truck. $275+shipping
First a set of RTE 3" front springs for a D1, RR4-3 225 in/lbs, which I think is the heavier spring. These have been on the front of my truck for 2-3 years, don't really remember, but aside from some surface rust due to rock chips they're good as new. $75+ shipping
A set of D1 front lower spring perches, I think they're the same as the rear, but have no clue. $10+shipping
D1 ABS pump, worked great the last time I had ABS sensors, should still be working great though I have no way of testing it, comes with the little mounting bracket too. No idea what these are worth, so how about $100+shipping
maxyedor is offline   Reply With Quote
