Links
Go Back   Land Rovers Only - Land Rover Forum > Land Rovers Only Classifieds > Land Rover Parts and Accessories
Old 12-28-2005, 09:18 PM   #1 (permalink)
Default TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE
Ok everyone it's time for the annual "get rid of your shit honey" sale. Not only have I piled up too much in loose parts but Project: Big-ass has just about broke the bank. I'd like to recoup some cash for the new year if at all possible. I've priced these parts well below what I believe is a good price already but if i'm off just let me know. I need to get rid of EVERYTHING so make a decent offer it's yours.
*Shipping & Handling - I don't mind shipping this stuff or sending it via Greyhound or Freight but the cost will be up to the buyer.
**Payment - Can be made via PayPal or personal check.
***BTW, I will donate 5% of each sale to the BBS you saw the ad on. Please be sure to let me know which one it was.
Email me direct DO NOT PM ME, jason@get-rhino.com with questions or to claim something.
THE LIST
Misc. Offroad. ETC…
RTE 5" front spring set Almost new $130.00
RTE 2" aluminum blocks, rear Almost new $100.00
100' 3/8 steel winch cable Brand New $45.00
Hella 500 rectangle lamp Used $20.00
Hella round rubber reverse lamp Used $15.00
Bearmach HD front steering bar w/
relocation kit Used $95.00
RoverTracks HD rear steering bar, Almost New $120.00
high clearence
RTE full bull bar w/ swivel recovery points & 2" bodylift mounting & skid plate, Almost New $950.00
Exhaust gasket, New, $5.00
Valve cover gasket & bolts, New, $15.00
4 flat -> 7 round euro trailer plug, New, $15.00
RoverTym 2" bodylift seat belt extensions set of four, $50.00
Bearing, RTC3406 clutch release???, New, $15.00
RoverTym 2" bodylife steering shaft extension, New, $15.00
Range Rover 4.0/4.6
Genuine dog guard Brand New $150.00
EAS overide module Brand New $100.00
Range Rover Classic / D1 Cross Over
RRC/Disco I turn signal switch/stalk, New, $55.00
Front drive shaft Used $65.00
Bosch coil Used $24.00
Rear link bushings at frame, DS Used $10.00
Rear link bushings at frame, PS Used $10.00
Mass air sensor 3AM Lucas Used $95.00
Rear upper shock mount, DS Used $25.00
Rear upper shock mount, PS Used $25.00
Spring plate Used $8.00
Front upper spring retainer ring Used $8.00
Genuine CD changer Used $65.00
Yellow relays Used $2.00
Green relays Used $2.00
Black relays Used $2.00
Front upper shock tower, DS Used $15.00
Front upper shock tower, PS Used $15.00
24 spline front axle housing Used $95.00
24 spline rear axle housing Used $95.00
10 spline front axle housing [dual lines] Used $95.00
10 spline rear axle housing Used $95.00
10 spline diff carrier Used $35.00
Exhaust manifold, DS Used $65.00
Exhaust manifold, PS Used $65.00
Front brake caliper, DS [1 line] Used $55.00
Front brake caliper, PS [1 line] Used $55.00
Rear link arm Used $20.00
Rear steering bar Used $20.00
Front steering bar Used $20.00
Roto-flex rear drive shaft Used $75.00
U-joint rear drive shaft Used $75.00
10 spline rear axle, short Used $45.00
10 spline rear axle, long Used $45.00
24 spline rear axle, short Used $55.00
24 spline rear axle, long Used $55.00
10 spline front axle, short [87-88] Used $55.00
10 spline fromt axle, long [87-88] Used $55.00
10 spline front axle, long [87-88] Used $55.00
Front sway bar setup Used $35.00
Rear sway bar setup Used $35.00
4.0 shortblock w/ heads, 70k Used $550.00
LT-230, 30k Used $450.00
ZF trans, has dime size hole from shaft Used $300.00
Range Rover Classic
Fuel pump assembly Used $65.00
Viscous fan clutch Used $75.00
Window lift ECU [PRC9949] Used $45.00
One touch ECU [PRC6859] Used $45.00
Dimmer switch Used $25.00
Fuel door popper switch Used $20.00
Turn signal bulb assembly, DS Used $15.00
Turn signal bulb assembly, PS Used $15.00
Front door upper w/ tinted glass, DS Used $45.00
Front door upper w/ tinted glass, PS Used $45.00
Rear door upper w/ tinted glass, DS Used $45.00
Rear door upper w/ tinted glass, PS Used $45.00
Rear fender section, DS Used $105.00
Rear door, complete, DS Used $115.00
Rear door, complete, PS Used $115.00
Tan leather, electric seat, DS Used $150.00
Tan leather, electric seat, PS Used $150.00
Discovery I
Hood Used $450.00
Front metal portion for bumper Used $55.00
Rear bumper, complete Used $85.00
Front door, lower, DS Used $65.00
Front sunroof Used $85.00
Rear sunroof Used $85.00
Stock foglamp, DS Used $35.00
Stock foglamp, PS Used $35.00
Subwoofer assembly, complete Used $65.00
Seat switch, DS Used $55.00
Seat switch, PS Used $55.00
Bumper light, PS Used $10.00
Rear view mirror Used $15.00
Sunroof motor Used $45.00
SRS ECU Used $150.00
Aribag ECU Used $150.00
Steering wheel airbag Used $100.00
PS side airbag Used $100.00
Door lock actuator Used $25.00
Fuse box Used $45.00
Sunroof ECU [AMR217] Used $65.00
A-pillar w/ tweeter, DS Used $35.00
A-pillar w/ tweeter, PS Used $35.00
Sunroof switch plate w/ switches Used $45.00
Transcooler lines Used $35.00
A/C line Used $35.00
Stock brake line, front Used $15.00
Stock brake line, rear Used $15.00
DS headlamp Used $45.00
DS mirror w/ glass Used $55.00
Plastic seat surround, DS Used $25.00
Plastic seat surround, PS Used $25.00
Roof rails Used $35.00
Tan carpet set, not mats Used $75.00
Aluminum steering shaft Used $75.00
Black leather t-box shift boot Used $25.00
Range Rover 4.4
PS side rear tail lamp Used $85.00
Freelander
Complete fan assembly Used $75.00
Series/Defender
Rear door Used $150
Front door complete, DS Used $150.00
Front door complete, PS Used $150.00
Rear door complete, DS Used $150.00
Rear door complete, PS Used $150.00
Front door, lower, DS Used $100.00
Front door, lower, PS Used $100.00
IIA fender, DS Used $100.00
IIA fender, PS Used $100
Rear seat Used $75.00
Front seat, DS Used $50
Front seat, PS Used 50
Rear jump seat, DS Used $50
Rear jump seat, PS Used $50.00
IIA front grill w/ lamps Used $75.00
IIA front grill, mesh part Used $65.00
IIA airbox, 4 cyl Used $45.00
RHD TDI Defender bulkhead
95% comp. Used $500.00
Defender fender, PS Used $150.00
SIII fender, DS Used $125.00
Defender seat box Used $75.00
Defender rear crossmember, HD Used $100.00
Defender light surround, DS Used $25.00
Defender light surround, PS Used $25.00
109 tub, tropical roof, sides,
glass, etc.. Used $750.00
Series hood w/ spare mount Used $250.00
RedRhinoProducts is offline   Reply With Quote
Old 12-29-2005, 07:35 AM   #2 (permalink)
Super Moderator
02disco2's Avatar
What, you don't have a stock pile in D2 parts and accessories?
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 12-29-2005, 07:37 AM   #3 (permalink)
rmuller's Avatar
That's what I was thinking
Old 12-29-2005, 10:48 AM   #4 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
You wouldn't happen to have any D1 front wiper arms would you?
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 12-29-2005, 01:40 PM   #5 (permalink)
DallasRover's Avatar
Sent you an e-mail. Don't have any skid plates, diff guards for a classic you want to unload do you?
Beer is proof that God loves us and wants us to be happy. ~Benjamin Franklin
1989 RR Classic
1969 Series IIA
3 Kids in College...........
DallasRover is offline   Reply With Quote
Old 10-16-2006, 08:53 PM   #6 (permalink)
Ello gu day mate ow r u?
r0cj0c's Avatar
whats the relocation kit for?, a steering damper?
r0cj0c is offline   Reply With Quote
Old 10-16-2006, 09:09 PM   #7 (permalink)
Rocky Mountain High
Funrover's Avatar
Yup!!!!!! Moves it up front like a d-90!
Old 10-16-2006, 09:21 PM   #8 (permalink)
RoverChic's Avatar
I am not sure Jason is doing the Rover thing anymore...last I heard he was going back to school or something of the sort. His site is down as of even date.
2006 Range Rover Sport HSE Rimini Red
2002 D2 4 SALE
2001 D2 CDL
1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired)
1988 RRC SWB ('Silver Bullet' Retired 05/98)
RoverChic is offline   Reply With Quote
Old 10-16-2006, 09:41 PM   #9 (permalink)
Rocky Mountain High
Funrover's Avatar
This post is OLD!!!!!!!!
