| View Poll Results: Retain 'em or Dislocate 'em | |||
| Retain 'em or Roll 'em |
24 | 68.57% |
| Cones rule, I'm cool |
11 | 31.43% |
| Voters: 35. You may not vote on this poll | |||
#31 (permalink) |
I was never happy with the amount of travel in the OME shocks in relation to the 21/2" lift I have ( not the shocks fault) I basically wanted extra droop on the wheels ( which it acomplished ) . As far as adding Long travel shocks this would be an excelent idea and fabbing up the Bracket plates would be a simple project. However at this point the components I have work well together and I am happy at the moment ,That is until I decide what route my next upgrade will be ( at that time I will want to upgrade the shocks)
Cheers. |
#32 (permalink) | |
Otherwise known as STEVE
#34 (permalink) | |
Todd Carpe Rangius Roverum |
#36 (permalink) |
Ian Matthews
Thor, it must have been modified as the picture posted by Duncan above is the standard setup, minus the dislocation of course.
It should never let go if the shocks are standard length or only a inch longer. |
#37 (permalink) | |
The Best 4X4XFar
Land Rover Discovery (3 Door) 200Tdi 5-speed ![]() Mods:Allisport LARGE FMIC | Allisport Tuned | Simex Jungle Trekker II 33.11.50R15 Tyres | 15x8 8 Spokes | Heavy Duty Uprated Suspension (shocks & springs) | Wheel arch Flares | 1" Wheel Spacers | Custom Straight Thru Exhaust | Custom Trimmed Front bumper with twin NATO Hooks | Custom Rear Bumper with single Large NATO Hook 360˚ Swival | Front Light Guards | Custom Aluminium Rear Floor | Bonnet Straps | 100w Spot Lights | Upgraded Headlights The Best 4X4XFar |
#38 (permalink) |
Ben
I have EE top and bottom spring retainers, it's overkill but their great if you want a retained set-up. Only problem is I have 762 rear springs and their stiff as an old man on viagra, so flex is limited. But I still don't trust cones and I've seen retained springs get more flex than cones before on a well tuned set-up and then he could drive home on the highway with no sway bars..
1997 D-90 #1345- Bunch of stuff 1992 RRC LSE- for sale/ maybe crawler project 2002 Dodge ram 2500CTD- dd/tow rig |
#39 (permalink) | ||
The Best 4X4XFar
And yes you could put your foot under it, but you'd also need to go to the hospital. You could see where it was sinking into the ground/depressing the ground. The weight of the wheel on it's would not do this. It all goes back to the fundamental function of how a live rear axle works. One hub goes up the other goes down. This is why the live rear was so favoured on so many rally cars as well as off roaders. Take a look at a Hummer (Hum-Vee/H1) off roading, sure it has great ride height due to the smooth underside and raised IRS setup. But because it's IRS it has no axle articulation. If one hub is forced up it has no direct result on the other.
#40 (permalink) | |
The Best 4X4XFar
#41 (permalink) | ||
The Best 4X4XFar
![]() As I've stated twice already in this thread the springs can pop out of the top retainer under full articulation on a 100% factory stock vehicle. This is why for ARC events it is permitted to use a plastic cable tie to attach the spring to the top retainer, thus preventing the springs popping out. This method was decided because if there is any rust present the cable tie is more likely to break before ripping the top retainer off the vehicle. EDIT: Here's is one of the Land Rovers which had the springs fall out the retainers. Apart from the required saftey equipment it is a bog standard 2.5 TD 90 truck cab.
#42 (permalink) | |
The upper shock mount is also reinforced (don't know exactly how to be honest). I've not had trouble with failed upper mounts and I've flexed the heck out of the front and rear of this rig. But I tend to crawl so less shock ( as opposed to catching air). I hope all holds up! The truck is a ton of fun!
#43 (permalink) |
Ian Matthews
300bhp, So what you are trying to say is that on a standard setup you can remove a spring without disconnecting the shock, LOL.
If you are going to lower the shock mount you should also lower the bump stops to stop the shock fully compressing. You do not gain any increased movement from this. There is little or no weight on the lower rear wheel of that orange disco. No hospital visit would be required. As stated previously, the restriction in IRS is largely due to the wishbone set-up. This vehicle has independeant suspension. I go out with him on a rtegular basis and it will outperform most 4WDs and it is stock. |
#44 (permalink) | |
Forward!
The six wheel drive might also help his cause!
1997 Disco 1 2000 Disco 2 1989 RR(gone but not forgotten )Miami Valley Land Rover Society www.mvlrs.com ON WISCONSIN |
#45 (permalink) |
One thing i have not mentioned in my post is the lack of Anti Sway bars. Given the fact that my shocks are + 11/2" and my lift is + 21/2" that would give me a total of 1" too short for the shock. ( if I had lowered it 1" it would bring everything back ) i chose the 2" to allow further droop on the wheels having said this it is fairly obvious from the picture that even with the shock in it,s original position it would seem to me the spring would still dislocate.(Now by leaving the sway bars connected , It would never allow the spring to disconnect) as for highway driving with no sway bars. My thought on this is simply before 92 it was an option on Discos and yes it is more stable having them conected and I have made disconnects for both the front and rear Although at the moment the rear are off as I have been making my gas tank guard and need to do a little refining in this area.
