Old 05-21-2008, 05:22 PM   #1 (permalink)
Default 4th Gear ratio incorrect code
I just purchased a 00 disco II. The service engine soon light came on. The code that came up was 4th gear ratio incorrect. Any ideas on what this could be. Today when I was driving home it seemed that the RPM's seemed a little high. It was around 4000 @ 70-75 MPH?
Thanks
Aaron
orange2 is offline   Reply With Quote
Old 05-21-2008, 06:38 PM   #2 (permalink)
ultrrunr's Avatar
Search for P0734 to see other posts about this. But, in short, you need a new MAF. Check with Tony at Cerrone's - Welcome to Cerrone's European
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
Old 05-22-2008, 05:17 AM   #3 (permalink)
No, you don't need a MAF yet, for that to be true, you would also need 2 other codes showing banks A and B running lean.
Check and see what type of air filter you are using, if it is a K&N, oiled filter, get rid of it today and go back to a standard paper filter cause K&N filters will kill your Bosch MAF.
Old 05-23-2008, 09:45 PM   #4 (permalink)
I'll check for other codes. I have only had the Discovory for a few days. I started checking it out last night. It had a dirty land rover air filter in it. Thanks for the advice
Old 05-24-2008, 04:56 AM   #5 (permalink)
Well, I would suggest you change out the filter, wipe out the filter box with a gamp cloth and then have the codes cleared. If the code comes back, go see Frank and see what else is going on.
Old 05-25-2008, 10:30 AM   #6 (permalink)
archaeology_student's Avatar
Gallery: 7
Isn't this thread supposed to be in the Tech & DIY forum? This is the general forum...
Yup, I run BioDiesel in my Series
MSN Blog with LR info and Photos
archaeology_student is offline   Reply With Quote
Old 06-20-2008, 08:53 PM   #7 (permalink)
It answered my questions just fine right where it is!
itsbob is offline   Reply With Quote
Code 48 - What does this mean? UsedBlue Discovery Series I 6 04-17-2008 12:40 PM
Gear 4 Ratio Incorrect MikeChiro01 Discovery Series II 14 04-16-2008 09:00 AM
NYTimes: Is 8 Enough? Transmissions Meet the Need for Speeds Adam in NYC USA General Land Rover Discussion 6 09-16-2006 08:21 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Discovery Tech Questions 62sunbeam Discovery Series I 9 12-22-2004 10:05 AM
