» Sponsors
» Sponsors
Old 05-08-2005, 06:52 PM   #1 (permalink)
Default 87 fuel problem?
hello there! first timer on this forum...i have a problem: MY 87 ROVER WONT GO! i can start it up and it will run fine for awhile, but eventually the gas cuts out and it starts chuging until it dies. it runs fine otherwise. we are thinking its a fuel pump problem or something blocking the air intake. any help would be appriciated....cheers!
-kelsey
yanni is offline   Reply With Quote
Old 05-08-2005, 07:19 PM   #2 (permalink)
Nacho Libre
Hailsharky's Avatar
Try changing the fuel filter first.
Its way cheaper then the fuel pump.
also, try ramming a bottle of techron down the gas tank just in case it needs some.
How long have you owned the rig?
Hailsharky is offline   Reply With Quote
Old 05-08-2005, 07:38 PM   #3 (permalink)
Nacho Libre
Hailsharky's Avatar
How old are the spark plug wires?
Could have a bad one.
Old 05-08-2005, 08:26 PM   #4 (permalink)
Disco's Avatar
Some more info if you please! How long have you had this problem? Has it just suddenly happened? Does it happen each time you start it? Have you had any work done on it recently? Does it only happen at start up or after you are rolling?
Old 05-08-2005, 10:45 PM   #5 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
Check the feul system for the following:
1) Loose crap or rust in your tank: With the suction created while the motor is running the stuff bloks the pipe. once the enjin dies the stuff floats away to other parts of the tank.
2) Carb running hot: If you have the old 2.25 enjin ('87 might still have them) and your carb is not 100% insolated from the manufold by means of a gasket it could happen that the carb becomes to hot and the feul in the float chamber acctually starts evapurating.
3) Pertol pump to hot: same as above
Electrical.
Check for cracks in the distributor. as the enjin is cold the crack is not critical but as it heats up and the metal/ plastic expands the crack widens and you start to "loose" spark
Old plug leads will also do this
Moeras is offline   Reply With Quote
Old 05-09-2005, 05:10 AM   #6 (permalink)
LRR219's Avatar
Tune Up Parts Can Be Purchased For Under Two Hundred Bucks Start There!
Don't follow us, you'll get stuck.
LRR219 is offline   Reply With Quote
Old 05-09-2005, 03:36 PM   #7 (permalink)
thanks for the help people! to answer some questions:
-it started doing this about a week or so ago
-i've had the car for a littel over a year
-have not had any major work (other than brakes) done on it
is there any chance i could get in and check the fuel filter myself? im no rover wiz, but i think with the help of one of my buddies we might be able to get in there. i will also check the spark plugs. i will ALSO throw some techron in there....
also, the car will run for a while, but will eventually crap out (mostly when you start going up an incline)
again, thank you guys for all of your help!!
Old 05-09-2005, 05:30 PM   #8 (permalink)
Disco's Avatar
Thanks for the input Yanni. Did you perhaps fill up with fuel after nearly running the tank dry? If so, you have probably got some crap blocking your fuel filter as a result. I would look here first. It's also possible that you may have a loose earth lead. Lets know how you make out.
Old 05-10-2005, 06:23 AM   #9 (permalink)
Profesional Hunter
dying on an incline is your petrol pump starting to pack up!
The pump still have enough vacume for level road and down hill but as soon as you go uphill it cant pump against the increased gravity. (youl also find the same symtom if you try to excalirate as fast as possible?)
Get a Recon kit for your pump. It is less than 1/2 hours work
SEO by vBSEO 3.3.2
