Hi,
New to the neighborhood and look forward to sharing LR RR info. I need your help on a question. I have a '97 Rover 4.0 and I'm trying to find out which of the 3 wires on my MAF Sensor supplies the voltage to the sensor. I need this info so I can tap into this line to install a Sensor Enhanser. From the schematic I have it looks like the Red/Blue wire #3 is ground but I don't know the color of #1 - ignition or #2 - voltage (which is the one I need) from the schematic. Any help would be sooooo grateful. Thanks. ![]() |
dont ever touch the lines on the maf sensor, fuck up the resistance and it will cause all sorts of issue with fueling and may even cause it to stall and not start again. any sensor enhancer is just a crock of shit. Dont fuck with a sensor or else get some really costly repair bills.
#3 (permalink) | |
The Urban Motorist
![]() Join Date: Sep 2004
pierburg
Awhile this may not be the same sensor, the connector pinouts may be similar. Do you know how to use a voltmeter?
-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=--=-==-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Owner of a 1996 Land Rover Discovery 1 in Beluga Black or the Dirt of the Day. Where we are going,we don't need roads. Nothing in education is so astonishing as the amount of ignorance it accumulates in the form of inert facts. ‘The Education of Henry Adams’ (1907) ch. 25 |
#5 (permalink) | |
#6 (permalink) | |
The Urban Motorist
One with be 12v and the last will be the varying voltage output from the sensor.
#7 (permalink) | |
#1 - output from sensor #2 - 12v #3 - ground |
#8 (permalink) | |
If not you could always use a needle probe from a voltomoter. (or how ever you spell it) What is this "enhancer" you speak of? Post details, i am quite sceptical. Also, once you instal it tell us how much better your truck works.....
![]() ![]() 77 SIII 88 97 D1 5 speed 91 D1 5 speed (the first, but gone )the lord is my weapon and i see him shoot pawns woman is the devil your god is a fraud |
#9 (permalink) |
The Urban Motorist
The enhancer is a fixed resistor or (adjustable 1kiloohm linear taper potientometer) that fools the ECU into thinking you are driving in very cold weather, adding max fuel into your air/fuel mix.
A good kit has the proper connectors / the bad kit just ships you the resistor and you have to figure out where to solder it in. There are better ways to do this but it's there.
#10 (permalink) | |
Speaking of . . . does anyone know of an accessible access to the engine from the drivers seat through the firewall? I can't find any opening that I can pass a 3/8" line from the drivers seat to the MAF sensor which is on the drivers side about 2-3' in front of the driver. Any help would be grateful as I have pulled the panel under the steering wheel to see if there is any existing routing to pass the line through but nothing I can see. Thanks. ![]() |
| Thread Tools | |
| Display Modes | |
| Famous Owners of Land Rover vehicles | Bleed Green RRC | The Lounge | 37 | 08-28-2006 12:40 PM |
| Land Rover Frequently Asked Dumb Questions (very long...but funny) | JungleRR | General Land Rover Discussion | 0 | 05-26-2006 09:37 AM |
| Land Rover: Truly 'Extraordinary' | Serg | General Land Rover Discussion | 0 | 01-30-2006 11:37 PM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 01:18 PM |
| Range Rover Sport Seems to have it all | Serg | General Land Rover Discussion | 1 | 12-05-2005 12:54 AM |
