» Sponsors
» Sponsors
Old 07-03-2009, 01:57 PM   #1 (permalink)
Default 99 landrover disco 2 quit running while driving
My land rover quit running while I was driving it...the check engine light came on instantly...i pulled over, got a tow home and let it sit over nite...it started right up the next morning...drove it for about 5 miles and the same thing happened...any ideas? I would greatly appreciate it
qb_1102 is offline   Reply With Quote
Old 07-03-2009, 02:29 PM   #2 (permalink)
Super Moderator
First, post your Discovery questions in the Discovery section, you'll have more exposer.
Is your check engine light on full time?
Old 07-04-2009, 07:13 AM   #3 (permalink)
TerryS's Avatar
Well, Let's see:
1. CEL came on INSTANTLY !
2. Pulled over.
3. Over night
4. Started right up, you jumped right back in it and drove 5 miles, probably without even popping the bonnet.
Given the rather complete list of clues, I'd say It's broken.
TerryS is online now   Reply With Quote
Old 07-04-2009, 02:05 PM   #4 (permalink)
XtremeMarine's Avatar
Damn; that was harsh. But truthful. What did you see when you checked under the hood the next morning? Fluid levels? Colors? DI - did you check the distributor cap, the wires, anything leaking under the truck? Did you check anything? Or just start it up and say to yourself " Oh, it started, everything must be fine..."
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 07-12-2009, 12:58 AM   #5 (permalink)
House Trained
Prodigy999's Avatar
You either need a crank sensor or a fuel pump. Sounds more like a crank sensor.
Prodigy999 is offline   Reply With Quote
Old 07-15-2009, 08:47 AM   #6 (permalink)
I was driving my disco II when the "M" and "S" signals started flashing and the car rapidly lost power. As much as I tried, it would not start. I waited an hour and tried again. It started right up and I drove it home. I have tried for two days now and it has not started. I bought a new battery yesterday and changed the terminals. Still not cranking up. Suggestions anynoe?
KOBLOKING is offline   Reply With Quote
Old 07-15-2009, 08:53 AM   #7 (permalink)
I had the same problem three days ago. I was driving my Disco II and the "M" and "S" started flashing on the dashboard. All of a sudden, the car lost power and came to stop -- would not start. I waited about an hour and tried starting it. It came on. I drove home -- ten minutes away. I have tried starting it since then and it would not come on -- cranking but not turning over. I replaced the battery and terminals. Still no good. These cars are just problematic. I dont know what to do at this point.
Old 07-15-2009, 09:28 AM   #8 (permalink)
Super Moderator
M/S are flashing, most likely because of a loose or dirty battery cable or a near dead battery, check that first including a battery/alternator test at your local car parts store. If you are still having a problem, I would think the crank sensor is failing.
Old 07-16-2009, 07:44 AM   #9 (permalink)
Hey DiscoMike. Thanks. I tried the new battery with new terminals. Still no luck. More than likely the cranck sensor. That will be my weekend project. Can't wait to get back on my disco. Miss it so much this week. This is my second Disco. Had a '96 Disco that had an electrical fire. This one (99 Disco II) is the replacement. As much as it gives me heartache (recently replaced intake manifold, waterpump before that etc, etc.), I am still an addict and can't stay away from rovers. Thanks a bunch.
Old 09-23-2009, 04:11 PM   #10 (permalink)
Default Sorry, havent checked this in a while
It turned out to be the Crank Sensor...thanks for all the responses.
Old 10-08-2009, 08:34 AM   #11 (permalink)
Beta testing www.discogirl4x4.com
DiscoDream2's Avatar
Crank position sensor...
1999 DII ~ ALPINE Edition
@>---^--- Discogirl4x4.com IS READY - COME VISIT! - Beta Version
Project DII:
New bumper cover w/trim, 2" lift, Bottorf Sliders, marker light, custom hood blackout, install DI CDL linkage, TW propshaft, diff guard-rear, mud plugs, Hi-Lift.
Completed
Head gaskets, synthetic oil, MAFS, coil pack, wires, alternator, tensioner pully, serp belt, PAS, fuel pump, 02/16" rims, 285/75/16 BFG KO, OE brush guard, wilderness roof rack, safari tail light guards, OE ladder, NATO fuel can, stereo upgrade, way cool oil gauge, Hella lights x6, CB radio, two rear trail/work lights.
DiscoDream2 is online now   Reply With Quote
To build a Def 100 from a Disco-1 nomad Hybrid 28 05-22-2009 11:16 PM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 07:33 PM
Do Disco I's drive easier than Disco II's? Beluga96 Discovery Series I 10 03-19-2007 11:09 PM
Disco running hot... revisited texasrover Discovery Series I 4 08-19-2006 04:20 PM
Help! 03 disco driving me crazy TBB Discovery Series I 6 02-14-2005 10:32 AM
