Old 06-21-2005, 12:36 PM   #1 (permalink)
Question belts
My '94 D90 squeals when I start it. I have adjusted the belts a few times and it works for a couple of days and starts squealing again. Any suggestions? It was like this when I bought it, and being a relatively new owner, I am not sure I have all of my bases covered.
Thanks.
monkey catcher is offline   Reply With Quote
Old 06-21-2005, 03:42 PM   #2 (permalink)
Nacho Libre
Hailsharky's Avatar
Are you sure its the belts and not the pullys?
What ever you do, dont use belt dressing.
It sounds like the bearings on the pullys are worn out.
That wont be fun to have seize up when your in a hot arid place.
Hailsharky is offline   Reply With Quote
Old 06-22-2005, 06:08 AM   #3 (permalink)
Talking
Another possibility worth checking is the waterpump - sounds silly but when they start to fail they will leak when cold. That being when there is no pressure in the cooling system to force the seal onto the shaft of the pump. The coolant can leak out onto the drive belt and cause a squeal on first start up in the morning. As the engine warms and pressure builds in the cooling system the leak stops and any coolant on the engine / belts evaporates.
Seen this on several other cars other than Landies so might be worth a check!
Agai n as above check all pulleys, tensioners and other ancillaries driven by the engine. Dry bearings can give the same symptoms.
Good luck!
Buckle
`66 Light Weight
Buckle is offline   Reply With Quote
Old 06-22-2005, 08:03 AM   #4 (permalink)
MISSING THE HELL OUT OF SEATTLE
Series 3 guy's Avatar
Gallery: 5
Good luck!
Not being funny, but does anyone else notice that the thread titled "Belts" was answered by the LRO chap "Buckle". I just thought that it was funny.Perhaps I should keep these things to myself and the voices that tell me to burn stuf.........
82' series III 109 safari prepared 2.25 pet.WILL NEVER GET RID OF!!!!!!
91'Range Rover classic 3.9L V8!(sold)
98' Land Rover Discovery with a MOD wolf 300 tdi(sold)
97' Defender 90 300 tdi (sold)
99' p38 Range 4.6 autobiography (sold)
2007 Porsche GT3..faster than the 109!
Series 3 guy is offline   Reply With Quote
Old 06-22-2005, 01:44 PM   #5 (permalink)
Default Thanks
These are great places to start. Thanks.
Old 06-23-2005, 07:42 AM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
Belt Buckle.
Thats classic.
I punch my clown daily.
Old 06-23-2005, 02:01 PM   #7 (permalink)
Talking
The pun wasn't intended!
Buckle
`66 Light Weight
Old 06-24-2005, 12:08 AM   #8 (permalink)
Profesional Hunter
Location: On the banks of the Great Grey-Green Greasy Limpopo River (Rudyard Kipling 1902)
Have you replaced the belt? It could have streatched, How old is it?
Moeras
’74 SIII 88” 345 000 Miles & still going strong!
Reality - an illusion caused by the lack of alcohol in the blood.
Moeras is offline   Reply With Quote
Old 07-07-2005, 12:47 PM   #9 (permalink)
Solution: Turns out that it is a slightly sticky alternator. The new belt is getting stretched a bit because of the relative difficulty of getting the thing to turn. Once its tightened, its fine for a few days, and then stretches a bit and squeals again. Although not necessary yet, a new alternator would fix it.
I guess this leads to another question: Being new to the Defender, is there anything I need to watch out for when replacing a D90 alternator?
Also, I apologize for not having put this in the Defender category.
Thanks.
Old 07-07-2005, 01:05 PM   #10 (permalink)
4x4 Adventure Gear
John C's Avatar
Replacing an alt on a D90 is very easy. You might want to consider a higher amp alt. I have the 200 amp Mean Green alt on my Disco and installed a 200 amp on a customers D90 w/o any problems. Just a thought.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-08-2005, 01:02 PM   #11 (permalink)
Default 200 amp?
This may be a naive question; What is the benefit of the 200 amp vs the stock (I think 120 amp) alternator?
Thanks for your replies.
