Coolant Leak (with pictures) - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 02-07-2010, 11:24 AM Thread Starter
OBauer809's Avatar
Quoted: 0 Post(s)
Ive had a small coolant leak for about 2 months, didnt really think much of it until now when its gotten alittle worse. Ive always been topping the overflow bottle off. I was taking a look at my engine today and noticed a small puddle of coolant on my engine block. I think its just a leaky hose or something minor (I hope). Ive attached some pictures of were the leak is. Im not 100% sure, but is that the water pump shown in the picture? Ive heard its common for the water pump to go bad..guess Im fearing the worse...
Anyways, your help is much appreciated, as always.
ID:	24285   Click image for larger version
ID:	24286   Click image for larger version
Oliver
2001 Discovery II - 3" Rovertym/OME lift, 2 KC's, 4 IPF's, modified custom front & rear bumpers, ARB diff-guards, skids.
OBauer809 is offline
post #2 of 7 (permalink) Old 02-07-2010, 11:25 AM Thread Starter
OBauer809's Avatar
Quoted: 0 Post(s)
Also I have a bad smell of coolant coming into the car..i think it gets worse when I have the heat or air on.
Oliver
post #3 of 7 (permalink) Old 02-07-2010, 11:29 AM
Quoted: 11 Post(s)
You have a leaking plenum deicer. To repair, you'll need a MGM000010K and an ERR6623 gasket.
Do it now, before you overheat and get to learn how to do head gaskets.
Yes, I am still alive, and still in the Rover parts business.
Text me for greatest likelihood of finding me.
260-804-0458
Dominic Perodeau/Global British is a thieving bastard, do not send him money.
PTSchram is offline
post #4 of 7 (permalink) Old 02-07-2010, 11:35 AM Thread Starter
OBauer809's Avatar
Quoted: 0 Post(s)
so I need to replace the throttle body plate & gasket?
and why learn to do head gaskets? see something wrong?
I know theres alittle oil accumulating there.
Oliver
post #5 of 7 (permalink) Old 02-07-2010, 12:50 PM Thread Starter
OBauer809's Avatar
Quoted: 0 Post(s)
I plan to order these parts as soon as I can. When I put these on, should I bleed the coolant system? If so can someone tell me how? I have no idea.
Oliver
post #6 of 7 (permalink) Old 02-11-2010, 07:54 AM
invisiped's Avatar
Quoted: 0 Post(s)
What he's saying in reference to "head gaskets" is that if you allow your vehicle to overheat, it displaces the steel sleeves around the pistons (because with overheating, your aluminum block and steel sleeves, contract and expand at different rates due to the different textures/ hardness of each different type of metal), creating overpressure--blowing your head gasket. No bueno! I've had to fight this fight and it's neither fast or cheap.
Rovin'
invisiped is offline
post #7 of 7 (permalink) Old 02-11-2010, 01:53 PM
FireUps
FireUps's Avatar
Quoted: 0 Post(s)
Coolant slow leak just burnt smell
I have the smell as well but only on the outside of the vehicle.. I can't seam to pinpoint the leak.. its small .. the fluid level is not changing.. any idea on things that might have a slight leak?
FireUps is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Coolant leak kevin2467 Discovery Series II 12 10-28-2009 08:29 AM
Coolant leak nordy Discovery Series II 2 10-01-2009 07:17 AM
Coolant Leak NAN Discovery Series II 23 04-04-2009 07:35 PM
Coolant leak... darkknight1999 Discovery Series II 16 01-01-2006 05:35 AM
You may post new threads
You may post replies
