ECU ?? how to test it?? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 11 (permalink) Old 05-07-2006, 10:46 AM Thread Starter
My Rover is Like a Junky Always Needs A FIX!!
Rudy R's Avatar
Quoted: 0 Post(s)
I have had some issues with my truck for some time now and just yesterday, I found that my ECU may be bad.
the rover tec swapped out my ECU with a unit he had at the shop he had me drive around and see just how it reacted.
well my old codes that would have come up Did Not..
the rover tec said, its you ECU but try these two things first before you replace it..
1. clean connectors with di electric grease
2. open the case and clean with electric parts cleaner.
so I went home and started at # 2
when I opened the case I seen dry mud on the side walls of the case not much but I guess hat was their could have done damage.
so I sprayed the cleaner all around and scrubbed with a tooth brush.
put back together and took for a ride.
I just don't know...
yesterday when I drove to the rover shop some 20 miles away the truck ran strong.
when their it even acted funny up for the rover tec to see and make his suggestions.
and after I cleaned the ECU it ran rough for a mile or so than went back to running good. but gave two NEW CODES P 1313 & P1314
????? is it the ecu or some thing else
any thoughts from the rover owners of the world.
( my wife said if I get rid of my rover I can have a girlfriend it would be cheaper)
Rudy R
96 Disco 1
my wife said, if I get rid of my rover I could have a girlfrend... she would be cheaper.
Rover On
Rudy R is offline
post #2 of 11 (permalink) Old 05-07-2006, 11:55 AM
Administrator
Quoted: 5 Post(s)
Rudy,
There is not alot you can do past cleaning, checking for burned connections on the boards and making for good connections. If the other ECU made the truck run well, sounds like your last step will be trying to buy that used ECU.
You most likely have caused a part to fail do to all the dirt, and tracking something like that, much less getting new parts and replacing them is probably something you can't or won't want to do.
Disco Mike is offline
post #3 of 11 (permalink) Old 05-08-2006, 02:56 AM
The Urban Motorist
Adam in NYC USA's Avatar
Quoted: 0 Post(s)
Unhappy
The LR ECU holds certain "internal "codes that don't come up at the Check Engine Light but can be read by a Autobook The new ECU is not expecting to see your oxygen sensors and were running in another car and the codes are popping up because there was no retraining time. Reset the ECU and then run the car for awhile.. I would reset the ECU with a Autobook and then see if the codes reappear.
I have a damaged ECU (it does not see the oxygen sensors) and have two replacement ECUs but I can only run them for two engine starts before the LR copy protection kicks in. Then I have to swap the old one in to get the 1996 D1 to start.
Would like that to work.
Adam in NYC USA
inert facts.
Adam in NYC USA is offline
post #4 of 11 (permalink) Old 05-08-2006, 12:50 PM Thread Starter
Rudy R's Avatar
Quoted: 0 Post(s)
adam
how do I reset the ecu?
what is an AUTOBOOK? is it a hand held computer?
thanks,
Rudy R
96 Disco 1
Rover On
Rudy R is offline
post #5 of 11 (permalink) Old 05-08-2006, 01:58 PM
The Urban Motorist
Quoted: 0 Post(s)
Okay.....
thanks,
Presumption: You have a Land Rover. You have to reset the ecu. A little history first.
About 1996 and later, the Land Rover (and most modern autombiles and trucks) adopted a standard called OBD II (or two). OBD II was implemented and allows for an automotive technican to get an more informed idea of what is going on inside the engine, dynamically, using a codereader or a laptop. You see a bunch of error codes and based on what kind, you can make an more informed guess of what is working/ not working/ not working well.
Now for the inside deal, fellow LRO member. There are codes that can be universally read by a OBD2 codereader and there are factory codes that only a Land Rover codereader can decipher. (For example, with a Testbook or Autobook, it can tell you if you have a defective thermostat awhile a stock OBD2 would not know how to read that code. It is part of what is called manufacturers codes.)
What can you do? Well, you can try to buy a testbook. It is an EXPENSIVE tool.
Or you can find a shop with one and then read off those interesting and hidden codes and then reset your ECU.
Can you reset your ECU? Yes. It helps if it throws a code first. Most if not all codereaders will not reset a ECU unless the Check Engine Light is first on.
Any more questions? Here is some reference on the Net.
http://www.rangerovers.net/repairdetails/scanners.html
http://www.troublecodes.net/landrvr/
Adam in NYC
inert facts.
post #6 of 11 (permalink) Old 05-08-2006, 09:15 PM Thread Starter
Rudy R's Avatar
Quoted: 0 Post(s)
thanks adam
I have a obd2 reader that clears codes.
Rudy R
96 Disco 1
Rover On
Rudy R is offline
post #7 of 11 (permalink) Old 05-09-2006, 10:40 AM
The Urban Motorist
Quoted: 0 Post(s)
Arrow Found this: Ohiodiagnostic codereader for Land Rover
Found this awhile searching the Net:
http://www.ohiodiagnostics.com/pages/landrover.html
I emailed them but just got a boilerplate email.
Details of the product can be found at https://www.ohiodiagnostics.com (I think they meant "http://")
Please call us at 330-668-1518 if you have additional questions
Thank you
-----Original Message-----
Sent: Monday, May 08, 2006 6:53 PM
To: info@ohiodiagnostics.com
Subject: Re: OBD2 codereader for Land Rover
Hello from Adam V
I am inquiring about your product for code reading Land Rover products.
Any information would be appreciated.
Adam V
If anyone has any more info, please chime in. The price would be nice as well.
Adam in NYC
inert facts.
post #8 of 11 (permalink) Old 05-09-2006, 11:26 AM
Otherwise known as STEVE
Quoted: 0 Post(s)
I looked at the 'virtual tour' which was just pictures of the screen- it doesn't look all that hot. The air suspension part seemed as if you can't test the suspension, but just look at the values from the sensors. The engine info didn't look like it provided any more than a $140 scan tool. If it can program keys and change BECM (they called it BECL) options, it would have some value- but it doesn't look anywhere near as easy to use or capable as the autologic or T4 etc. I'm betting it ain't cheap either... I dunno.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Muddy Oval is offline
post #9 of 11 (permalink) Old 05-09-2006, 11:41 AM
The Urban Motorist
Quoted: 0 Post(s)
Wtf?
Damn, Steve, I want to fix my Rover and you want a PSP to play with. If I can afford it, don't you think I want it?
I personally need to reset two new replacement ECUs to my BECM and I can't without spending a small fortune. I have two spare ECUs and I cant use them on my D1 right now.
What are you looking at? An introductory virtual tour. I don't want to be in your shoes if the stupid tour was about a new Land Rover.
Damn.
ID:	6833   Click image for larger version
inert facts.
post #10 of 11 (permalink) Old 05-09-2006, 01:01 PM
Quoted: 0 Post(s)
I'm afraid that didn't make sense. Was there a price posted? I know their BMW unit costs as much as an Autologic but with less function.
If the Rover version is affordable, it's probably fairly useful... Wouldn't it be cheaper to just have your ECU's done by a shop that has the tool and just pay them for the time?
All I'm saying is that without price info- it's hard to tell if it stacks up against the other stuff out there.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
post #11 of 11 (permalink) Old 05-09-2006, 01:21 PM
The Urban Motorist
Quoted: 0 Post(s)
We can both agree on that.
I am looking for a affordable tool to solve my problem on my end, a bad ECU. You are looking for a fancy box that can double as, what I don't know.
If you think there are any dependable shops in NYC, I can tell you as a used Land Rover owner, they are as scarce as hens teeth. Or RoverX's virginity.
Right now, it would be nice to fix all this with a laptop. Sigh.
Adam in NYC.
inert facts.
Closed Thread
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
