Old 05-17-2008, 06:19 AM   #1 (permalink)
polar's Avatar
Default Engine Compression?
In the Rave CD it states a low compression engine and a high compression engine.
How do you tell which engine you may have?
2002 Discovery 4.0 55K
Delo 400 5W-40 synthetic
CI-4 PLUS, CI-4, CH-4, SL (SAE 5W-40)
Zinc=1310
Phosphorus=1560
polar is offline   Reply With Quote
Old 05-17-2008, 06:24 AM   #2 (permalink)
Yours should be the 9.35 to 1 compression engine.
Old 05-17-2008, 02:39 PM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
It is stamped just above the engine number, near the oil dip stick, on the block.
Old 05-17-2008, 02:43 PM   #4 (permalink)
polar's Avatar
Ok, Thanks,
I will give the block a look.
Zinc=1310
Phosphorus=1560
Gasoline Otto Engine No start/Misfire Diag Principles. Elemental Tech & DIY 3 07-05-2008 05:42 PM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
