Hi All,
I'm getting ready to complete the coil lift on my P38. I just had a question regarding how much front end sag I can expect so I can remedy it using trim packers. The winch mount weighs about 80lbs and I'll be adding a 9,000 lb winch to it. My lift consist of the Terrafirma 223HD with an additional 1" spacer. I haven't been able to find any specific information regarding the TF springs, however from research I have read that it may sag up to 1.5 inches. I've already purchased 6 10mm trim packers. I was planning on adding 1 in the rear, and 2 in the front to even everything out. I want to do this once and not have to uninstall the springs to add more height if I can avoid it.
Can anyone advise if what I plan on doing should make up for any sag? I realize that it's impossible to know without actually mounting everything up, however, I'm just trying to plan ahead and avoid taking things apart for adjustments if necessary.
Thanks in advance.
Thanks in advance.
