Old 01-17-2008, 09:32 AM   #1 (permalink)
YellowFever's Avatar
Default Extended Warranty for a 00 to 02 Range?
Has anyone out there tried the extended warranty from Auto Advantage? I am close to buying a 00 to 02 Range and was thinking about getting this as well:
THIS PLAN IS THE BEST MAJOR COMPONENT COVERAGE AVAILABLE.
Warranty Offered By: Auto Advantage Inc.
“WHAT IS COVERED"
***Driver's Choice Coverage***
Engine and Water Pump: The following parts of gasoline and diesel engines: pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and camshaft bearings, timing chain and timing gears, intake and exhaust valves, valve springs, oil pump, push rods, rocker arms, hydraulic lifters, rocker arm shafts and water pump. The engine block and cylinder heads are covered only if damaged by a part listed above.
Transmission: The following parts of manual or automatic transmissions: torque converter, oil pump, governor, bands, drums, planetaries, sun gear and shell, sprag(s), shaft(s), bearings, shift rail, forks, and synchronizers.
Drive Axle Assembly: Drive shaft, ring & pinion gears, pinion bearings, side carrier bearings, carrier assembly, axle & axle bearings, universal & CV joints except if boot is damaged or missing. Drive axle housing is covered if damaged by a broken listed covered part.
4X4 Transfer Case: Internally lubricated parts of the 4x4 transfer case.
Air Conditioner: Compressor, condenser, evaporator, orifice tube.
Electrical: Alternator, voltage regulator, power window motor, heater fan, starter motor. No other electrical components are covered by this program.
Seals & Gaskets: Seals and gaskets are replaced only as part of repair or replacement of the above covered components.
Car Rental & Towing: This program provides a total of $150 for car rental and a total of $100 for towing. Car rental & towing will be paid on valid, authorized claims only.
Labor & Diagnostic Charges: Are covered in conjunction with an authorized repair on above listed components.
$0.00 Deductible
3 Year/Unlimited Additional Miles- $1,029.00
5 Year/150,000 Additional Miles- $1,099.00
7 Year/100,000 Additional Miles- $1,079.00
YellowFever is offline   Reply With Quote
Old 01-17-2008, 01:19 PM   #2 (permalink)
XtremeMarine's Avatar
With a Rover, buy the most extended coverage that you can afford. Honestly. I didn't buy one for mine, and man did I pay out the nose. Less than six months after the four years was up, and still well under 40K; My power steering pump pulley bearing froze up. It blew the serpentine belt, and the engine overheated. Granted I have a 4.6 in there now, but it was over 7k to do the job. Would rather just have a 40k mile 4.0, and only have spent a grand on a warrantee.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 01-17-2008, 01:26 PM   #3 (permalink)
2004 Discovery II driver
i have an extended aftermarket warranty on my 2004. i still have a factory one for 2 more years. definetly go with w/e is their premium/platinum package.
stolenheron is offline   Reply With Quote
Old 01-17-2008, 01:55 PM   #4 (permalink)
Default I know a good place...
I have a policy on my Rover and so far it has been OUTSTANDING! Check them out as well.
Auto Warranty, Truck Warranty - Land Rover Extended Warranties - Extended Auto Warranty Specialists, Truck, Car Warranties, New, Used Vehicles
SunStruckAZ is offline   Reply With Quote
Old 01-17-2008, 02:00 PM   #5 (permalink)
They are just way too expensive to repair. I am sure others would agree.
Anyone who owns a Land Rover should never leave their driveway without a warranty.
Old 01-18-2008, 09:13 AM   #6 (permalink)
Except for the breaks! I was shocked how easy it was. Took me longer to get the wheels off than to change the pads! I didn't even ask how much the dealer wanted to do it. I am sure a lot!
Remember: Success is nothing but luck. Just ask any failure. - anon
Show me a good loser, and I'll show you a loser. Vince Lombardi
Extended Warranty? OkieRover Discovery Series II 19 01-17-2008 02:06 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Range Rover Sport Seems to have it all Serg General Land Rover Discussion 1 12-05-2005 12:54 AM
Extended Warranty Info FlyWheel Discovery Series II 2 09-29-2005 09:26 AM
Extended Warranty or "Not"? '02 Disco II Discovery Series II 6 07-06-2005 09:31 AM
