Old 06-21-2006, 12:28 PM   #1 (permalink)
Default headers and such
does anyone know whether that be by experience or by word of mouth if using header insulation wrap has any affect on a vehicles performance? supposedly the insulation is to be wraped completely around the headers and this is supposed to do two things. It will keep the heat in the headers instead of letting that heat come out into the engine bay. so the temp level in the pipes is higher which means faster flowing exhaust. also the engine bay is cooler so the temperature of the air taken in by the engine is slightly lower. ive seen the wrap for only $1 per foot, so if it does work it would not cost much money at all.
awdsubs is offline   Reply With Quote
Old 06-21-2006, 12:41 PM   #2 (permalink)
RIP Trooper Shawn Blanton
WCURoverD90's Avatar
Gallery: 10
Interesting...If it works it would be something to look into to....Sounds like it would be relatively cheap.
"All those that believe in Telekinesis, Raise my hand'
"If I wanted a Hummer, I would call your girlfriend"
Rovers
97 Defender 90 Soft Top
2005 LR3 HSE
1956 Series 1 107 Tow Truck
WCURoverD90 is offline   Reply With Quote
Old 06-21-2006, 12:50 PM   #3 (permalink)
He did what in his cup???
DevilDisco's Avatar
I have heard of the wraps but I think they might also hold moisture and cause the Manifolds to rust faster. They have similar products for intake systems as well.
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 06-21-2006, 12:55 PM   #4 (permalink)
4x4 Adventure Gear
John C's Avatar
Ditto
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 06-21-2006, 01:09 PM   #5 (permalink)
Yes it does work in the described ways
Yes they also have ones for intake
Yes they will hold mud and moisture and rust your headers
Answer is ceramic coat all the benifits none of the problem's
Negative is ceramic coat costs more than cheap headers and unless your going janspeed I wouldn't waste the money, the difference it makes isn't enough to warrant the expense al least for me. get a dual electric fan setup
I refuse to tip toe through Life only to arrive safely at Death
Rocks, Sand, Mud, Water whatever I just want to leave the pavement
Its your Life, LIVE it ENJOY it!
DiscoPilot is offline   Reply With Quote
Old 06-21-2006, 07:51 PM   #6 (permalink)
Otherwise known as STEVE
I just had some Rover manifolds jet-hot coated... I'll get some pics, they look great!
I use header wrap on my race car- it has to be changed every year or so and it a pain to deal with. I doubt the benefit, if any, would be worth the hassle on a Disco. The stock manifolds would be nearly impossible to wrap properly because of the shape anyway I would think.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
