Old 12-02-2005, 02:11 PM   #1 (permalink)
Unhappy Help!!
Please can anyone advise me.
I have just put £15.00 of petrol in my Discovery, I already had 1/4 of a tank and once I realised my error, I topped up the tank with £45.00 worth of diesel.
If I continue to top up with diesel will this be okay?
munbob is offline   Reply With Quote
Old 12-02-2005, 02:42 PM   #2 (permalink)
DISCO INCUBUS's Avatar
Default ???
If you have 1/4 tank full of petrol in a diesel tank DRAIN IT NOW.
Diesel fuel has lubricating properties , petrol does not.
DISCO INCUBUS is offline   Reply With Quote
Old 12-02-2005, 06:21 PM   #3 (permalink)
dont drive it. drain the tank.
To drain the tank you need to take out off the lower filler hose.
Its not too hard. then get a pump and pump it out.
If you dont have the ability to do so get it towed to the shop.
you will also need to change the fuel filter and drain the lines.
If you dont your screwed.
No lubricating qualities mean the injectors and pump will be damaged.
Old 12-02-2005, 06:26 PM   #4 (permalink)
My Rover is Like a Junky Always Needs A FIX!!
Rudy R's Avatar
Exclamation oooh no!!!
I know a guy that did the samething with his BMW 325
he spent over $ 500.00 US to have the system flushed out.
good luck BUNBOB
Rudy R
96 Disco 1
my wife said, if I get rid of my rover I could have a girlfrend... she would be cheaper.
Rover On
Rudy R is offline   Reply With Quote
Old 12-02-2005, 06:35 PM   #5 (permalink)
Default ?
good luck BUNBOB
I think his name is munbob but if he drives the truck around like it is it
will be Burnbob.
Just kidding munbob good luck
Old 12-02-2005, 06:42 PM   #6 (permalink)
I cant tell you how many Ford Truck Diesel owners that have done it.
The lucky ones realize it at the moment at the pump.
The idiots drive off and ruin a few if not all the oil pressurized injectors.
They run four hundred bucks a pop.
basically the diesel fuel actually has lubricating properties that gas doesnt have.
Old 12-05-2005, 10:36 PM   #7 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
Man I sure hope he didnt even crank that engine.
It happened to me twice, Once with my BMW M5 Euro and my BMW 525 Euro..both tanks have huge mouths and will accompodate any pump...good thing I caught the errors at the pump.
Good luck there MUNBOB.
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
