Old 09-02-2005, 06:45 PM   #1 (permalink)
Default Ignition Wire Sequence
I've got a '96 Disco that was in dire need of new plugs and ignition wires. In the process of installing a wrong set of wires I received from Atlantic British (they sent me the set that went with a distributor), I think I mixed up the sequence from the coil block to the cylinders. Can anyone enlighten me as to which coil block socket goes with which cylinder?
Thanks,
SRR
SRRobirds is offline   Reply With Quote
Old 09-02-2005, 07:43 PM   #2 (permalink)
Elephantitis penisitis
Damnit, started drinking too early. Got a 96 in the driveway...be back in a few minutes after I map out the sequence...shut up Griff.
Old 09-02-2005, 08:16 PM   #3 (permalink)
OK...bear with me on this...
coil block 1 2 3 4 5 6 7 8
engine 8 7
6 5
4 3
2 1
Front
OK, follow me on this...the first number will be the coil block number and the second will be the engine cylinder. I am not a mechanic so I figured this the best I could by looking at my engine. I may have the names messed up but this should help you:
1 - 2
2 - 5
3 - 4
4 - 7
5 - 8
6 - 3
7 - 6
8 - 1
Got it? Hope this is clear enough for you. Any more questions, just call me (209) 585-5265.
Steven
Old 09-03-2005, 06:15 AM   #4 (permalink)
Default Your are the MAN
My Rover has new life, and purrs like a kitten!! Next time you're in Atlanta I'll buy you a beer!!
Thanks,
SRR
Old 09-03-2005, 11:37 AM   #5 (permalink)
You are welcome sir! I'll take you up on that beer next year!
