Kingsborne 8mm vs STI 8mm vs NGK 8mm wires - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 04-03-2017, 06:50 AM Thread Starter
Disco Chai
DiscoveryChai's Avatar
Quoted: 2 Post(s)
Garage
TECHNICALLY whats the best for 2000 discovery 2 (V8,4.o,auto,gass,192k).then bosch platinum plus 4's,E3's,ect.? Just wanted some technical knowledge, Thanks everyone!
DiscoveryChai is offline
post #2 of 5 (permalink) Old 04-03-2017, 07:26 AM
Quoted: 290 Post(s)
By TECHNICALLY, I believe you're asking for some factual substantiation. That's hard. I guess by the purest of definition, you need to be putting the OEM plug into it as that's what it was all designed around. However, I think it's pretty well-accepted that the OEM wires weren't all that great, and that replacements do have a positive effect, so maybe the factory isn't the last word.
IMO, I think plugs like the plus 4 work better in a modern vehicle that runs a much cleaner combustion process and uses a more sophisticated ignition system (higher energy, multi-strike). As I posted in your other thread, my best results have been with the Bosch Iridium and the Champion Double Platinum. If you have a dirty-running engine, with cheap wires, worn rings, etc, you'll probably get the best results with basic copper. It's all about the best path to the spark cap and none of those materials is a better conductor than copper. The E3 is a pure copper electrode.
Your thread title and the topic of your post differ- you ask about wires, then plugs. I assume you're looking for feedback on both.
On wires, I was unaware that NGK made an 8mm set for the Rover. They're OEM replacement is just that- equivalent to a wire that can definitely be improved upon. I like the STI- I think it's the best bang for the buck. I would certainly concede that a wire like the Magnacore is better, but the Rover doesn't have the current to take advantage of it. Can't comment on the third option.
CT090 is offline
post #3 of 5 (permalink) Old 04-07-2017, 07:47 PM
DISCOlorado's Avatar
Quoted: 3 Post(s)
I don't know much about spark plugs and wires but this is my experience.
I bought new NGK Platinums, it ran good, I swapped over to the Bosch Iridium and it ran like silk.
Don't know much about wires either, I bought the NGKs online and 3 of them already broke where the metal tube goes into the spark plug. That being said they're a nice color but they're junk in my opinion. I'd go with STIs or the Kingsbourne, I don't know how much better they are but hopefully better thank the NGKs
Sent from my iPhone using Tapatalk
DISCOlorado is offline
post #4 of 5 (permalink) Old 04-08-2017, 06:05 AM
Quoted: 290 Post(s)
It all falls into the category of "you get what you pay for". The caveat, though, is "how much do you really need". The NGK is an OEM replacement. That's not "equivalent". It will do the job of the OEM, but not last nearly as long or have the same structural quality. The OEM is very high quality, but electrically inadequate. The truck doesn't run bad with therm, but it can run better with other options.
CT090 is offline
post #5 of 5 (permalink) Old 04-08-2017, 04:43 PM
Ian Matthews
p76rangie's Avatar
Quoted: 161 Post(s)
In reality you will not notice any difference between the various brand of leads. The only time you may notice a slight difference is in the high rev range, which most people would never go into.
p76rangie is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rovers Only General Forums > General Land Rover Discussion
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
STI Wires- 8MM, or... CT090 Discovery Series II 2 03-16-2016 11:57 AM
STI 8mm Wire Lifespan knesbeck Discovery Series II 4 04-17-2013 05:26 AM
STI 8mm Plug Wires advntr12 Discovery Series II 8 05-28-2011 06:34 AM
Kingsborne IGN 790 8mm plug wires DiscoKline Land Rover Parts and Accessories 6 02-25-2011 10:29 AM
8MM Magnecor wires flyboyaviator Discovery Series II 10 08-13-2010 05:20 PM
You may post new threads
You may post replies
